let me try to clear this
a 10m radio operates in only the 10m band and cannot be changed. a export radio is a 10m radio that can be converted to be used on the
cb band- these are rangers, cobras, magnums, galaxy's and clones etc they are not true ham radio's. a ham radio will not come with echo, a retard beep, "band" switches or a channel display. a
hf radio will cover from 160m-10m (all
hf bands)- these are kenwoods, yeasu's, icom's and allinco's. as you notice real ham radios only show a frequency, as there are no channels on ham.
cb's have channels so its easier for the uneducated public to operate.
exports do not come with ctcss boards or abilitys to install one*. (sub tones for activating a repeater) exports were designed as high power
cb's that cover the common out of band frequencys. they are called 10m radios as a way for them to be shipped into this country, they are not. they are illegal to own, operate, distribute, or sell in the united states and controling territorys.
i guess the easy way to say it is you cannot buy a new 10m radio, they are all exports now a days. you get cought with one and its a big fine (up to $10,000) and it becomes theres.
95% of 10m phone transmissions are done via upper sideband, the remaining balance is
fm use for repeaters.
am is not used much at all. most early
hf rigs did not have
am, it wasnt untill the 70's that
am started to be built into the radios. cw is the most common way to transmit on 10m.
*the new 2950dx series radios and uniden hr2600's had optional ctcss boards available. they are still considered exports as they can be easily modified to be used on the 11m band.
