Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > General Ham Radio Discussion
Amateur Callsign Lookup
Enter Callsign:
Interesting reading,
Reply
  #1
Old 08-12-2007, 06:43 AM
datsun66's Avatar
Senior Member
datsun66 is on a distinguished road
Default Interesting reading,
I copied this article from the AARL web site. Any Opinions?
HF Amplifiers versus Antennas—One Ham’s Opinion
Think you need a shiny new linear amplifier to chase away your HF radio blues? Think again. What you probably need is a better antenna! Here’s why....
By Kirk A. Kleinschmidt, NT0Z, 16928 Grove St, Little Falls, MN 56345, kirk@cloudnet.com
Let’s start by eliminating any thoughts of fairness and equality regarding this article’s handling of the age-old philosophical struggle between amplifiers and antennas.
More than a few hams will take exception to my biased statements (common when trampling sacred cows and sneering at tradition), but if you’re a typical beginning ham, you’re probably wondering whether to buy an amplifier or improve your antenna system—or maybe both.
It’s a logical question. You want to improve your station’s signal quality, make more QSOs, work more DX stations, rack up higher contest scores and chat with others while enjoying armchair copy.
You want to know whether amplifiers are a good investment, whether they’ll require additional equipment and services, whether they’ll provide the boost in readability you’ve been desiring and so on.
By now you’re thinking that I’m an "antenna guy," and that I’m here—through this article—to persuade you to improve your antenna system. You’re right!
But beyond the many nuts and bolts reasons detailed herein, I’d like you to at least consider a few philosophical reasons to keep your power output at barefoot levels (or less!). Then, if you’re not convinced, we’ll take a look at the cold, hard facts about amplifiers and antennas.
Amateur Radio’s Middle Path
Amateur Radio operation in the US is constituted as a radio service, with rules, regulations and goals that go beyond the interest of mere hobby operation. In becoming licensed hams, we agreed to play by those rules. One of the most important rules compels us to use the minimum transmitter power required to communicate.
That doesn’t rule out the use of linear amplifiers, of course, but it does put a damper on their indiscriminate or habitual use. Powering your amplifier through your shack’s light switch certainly violates the rule, as does running maximum legal output power when chatting with the gang across town (or when propagation clearly doesn’t require it).
The minimum necessary power rule is designed to protect us all. It promotes responsible, considerate operation. Try it sometime! Reduce your 100-W signal to 50 or 25 W. Thanks to years of low-power operating, I know that you’ll maintain effective communication most of the time. You’ll also improve your operating skills, enjoy a greater sense of achievement and gain an intuitive sense of propagation.
By the way, the FCC’s minimum necessary power rule isn’t suspended for contest operation, to work DXpeditions, etc. About the only open-and-shut case for the automatic use of maximum available power is for emergency communications. When someone’s life is on the line, the more power the better. That kind of service is what the Amateur Radio Service is all about.
Skill Versus Brute Force
Long before David and Goliath had their epic battle, skill has been tangling with brute force. I’m sure you have your favorite analogy. Basically, it comes down to the fact that any idiot can fire up a water-cooled Voice of America-size transmitter and blurt out a whopping signal. I place hams who take this approach in the same category as the guys who screech the tires on their 1-ton pickups or water their lawns during drought emergencies. Both are equally impressive, I’m sure.
On the other hand, if you align yourself with the Davids of the world, substituting skill and persistence for brute force, you’ll be in better company—and you’ll be upholding the tenets of the Amateur Radio Service.
The Golden Rule
November QST: HF Amplifiers versus Antennas—One Ham’s Opinion - Page 1 ARRL 1998 QST/QEX/NCJ CD C i ht (C) 1999 b Th A i R di R l L I
Hams treading the Middle Path are concerned about others—hams, neighbors, family members, etc. They try to fit in, to get along, to accommodate a community of interests in addition to their own. They practice the Golden Rule Do unto others as you would have them do unto you (reasonable variations notwithstanding).
As hams who comprise a federally licensed emergency service, we enjoy certain protections from unreasonable local restriction. These privileges are welcome and necessary as a whole, but they can be easily abused.
Just because we can transmit a 1500-W signal doesn’t mean we should. Just because we can erect a 200-foot-high antenna tower doesn’t mean we should. Hams who follow the Golden Rule integrate their radio pursuits with the pursuits of others—not because they have to, but because they want to!
Governments can’t legislate common sense. That’s up to us.
Okay, that’s the end of my emotional pitch for restraint. If you’re still tempted to reach for the power switch (the high power switch) or dig into your rainy day fund to purchase an amplifier, let’s look at the facts.
The Ham Next Door
To start, let’s assume that you have a typical shack. A 100-W transceiver graces your operating desk and "talks" to a coax-fed dipole (or two) through a 300-W antenna tuner. Thanks to the tuner, your rig can happily put out full power regardless of actual antenna/feed line SWRs on the various bands you work.
You use the same setup as your "Elmer" and most of the guys in the local radio club. Uncounted thousands of hams have used similar setups over the years, so they must work pretty well, right?
Maybe. But maybe not. In fact, you might have noticed that working stations on some bands doesn’t seem as easy as it should—especially DX stations. You might even be dreaming of solving your problem by cranking up the power. By adding a gleaming, glowing monster amp to your modest shack, you might think, those stations with once-marginal copy will respond with ease.
It’s a comforting image, but it’s probably more fantasy than reality. Although you may not yet know it, you’ll likely get a lot more signal for a lot less money if you upgrade your antenna system before shelling out the bucks for an amplifier.
The Price of Power
Let’s boost our signal a step or two at a time and see how the decibels stack up against the greenbacks.
If your amplifier budget is modest, a small solid-state or single-tube amplifier will boost your 100-W barefoot signal to about 500
W. That’s enough to be noticed, or so you think—but just how noticeable?
Here’s the law every amplifier has to measure up to Every time you double your power output, stations that are receiving your signal hear a 3-dB increase in strength. That’s half an S unit! To twitch the needle a full S unit you need to quadruple your power output (a 6-dB increase)!
The power output progression looks like this 100 W doubled to 200 W equals a 3-dB increase. Next, 200 W doubled to 400 W equals a 6-dB increase. Then, 400 W doubled to 800 W equals a 9-dB increase (exceeding the output power of our entry-level amplifier). Finally, 100 W times 10 equals 1000 W, a 10-dB increase in power output.
Our 500-W output amplifier gives us a smidgen more than a one S-unit boost on the other end (see Figure 1). That’s not much—especially when you consider the cost.
November QST: HF Amplifiers versus Antennas—One Ham’s Opinion - Page 2 ARRL 1998 QST/QEX/NCJ CD C i ht (C) 1999 b Th A i R di R l L I
Figure 1—Spend a wad of cash on an RF power amplifier and what do you get? Let’s assume that we have an average conversation in progress on a quiet band. Your current 100-W signal pushes an S meter on the receiving end to S5. Increase your output to 500 W and the other guy’s meter might slide up to a tad more than S6—a change he won’t even notice. Turn on the 1000-W afterburner and you’ll make his meter twitch almost to S7. Oh boy! Yes, he’ll probably notice a difference now, but he heard you well enough at S5, didn’t he?
More Power
So, you want to run even more power? Using our calculations from before, boosting your signal to a kilowatt output provides a 10-dB shot in the arm. That’s just under two S units on the other end—S3 to S5, S7 to S9, etc.
That’s enough of a difference to be noticed, but still not enough to "burn down the barn." And by the way, the most affordable kilowatt amplifiers cost about $1500. If you really go for the gusto and buy a legal-limit amplifier, your 1500-W signal will be about 12 dB stronger than your "barefoot" transceiver. Because of the "price of power," 1500 W is still only two S units stronger! And a legal-limit amplifier is hardly a casual purchase. It’ll set your wallet back about $2500.
Hidden Costs
Don’t think you can get away with just an amplifier! The power output curve is often deceptive. For example, above 300 W output or so, you’ll need a beefier antenna tuner. Expect to spend up to $500 for a good one.
And don’t forget about the ac mains, either. You can probably get away with running a 500-W output amplifier on 120 V ac, but beyond that, it’s 240 V all the way. (Don’t believe me? A 500-W output amplifier runs about 1000 W input power. That’s 8.5 A at 120
V. With your rig added in, that’s more than 10 A. Believe me, the lights in your house will "jump" to the rhythm of your code key or your spoken words!)
Chances are good that you won’t know how (or won’t want) install that 240-V line yourself, either. The materials and an electrician to install them likely will total $300 to $500. Many first-time amplifier users don’t consider their beast’s power supply requirements until they’ve set up the amp and started "browning out" the rest of their house! If this is you, you’ll be lucky if you don’t trash your TV set or your home computer in the process of "modulating" your 120-V power feed!
If you live in an urban setting, don’t neglect the potential "public relations" costs of firing up a killer signal in the midst of all those consumer electronics devices. I know...you can legally stand on the solid rock of FCC-mandated power output limits—but be warned that it can be a lonely vigil.
A Better Way?
To save wear and tear on your neighbors, fellow hams, your wallet and even your house wiring, consider improving your antenna system before investing in an amplifier. Here are some ideas to get you started
One almost universal way to get out more signal is to get your antenna(s) farther up in the air (your present antenna or a new
November QST: HF Amplifiers versus Antennas—One Ham’s Opinion - Page 3 ARRL 1998 QST/QEX/NCJ CD C i ht (C) 1999 b Th A i R di R l L I
one). Build a taller mast, find a taller tree or put up a tower.
If that dipole just isn’t cutting it, put up a contest-winning and DX-catching secret weapon a full-wave horizontal loop for 40 or 80 meters (up as high as possible, of course!). Feed it with coax and use a tuner on bands above the fundamental frequency. That’s a "cheap ‘n’ dirty" way to snag an extra 2 to 10 dB, depending on frequency.
Disconnect the feed line from your coax-fed single-band dipole, the one you try to use on several bands, and replace it with
450-Ω ladder line (see Figure 2). With a coax feed, even though your antenna tuner may be presenting a happy impedance to your transmitter, feed line losses due to high SWR may slash your signal by 6, 10 or 25 dB, depending on the band and the size of your dipole! By using 450-Ω open-wire line you’ll likely reclaim most of that lost power. Now that’s a 6 to 20-dB shot in the arm that
anyone can afford!
Figure 2—You can increase the performance of a simple dipole by using low-loss open-wire 450- windowed feed line. This is one of the easiest, inexpensive antennas for the HF beginner. Just string up a dipole made of two equal lengths of copper wire. Don’t worry about the overall length; just make it as long as you can. Connect the feed line to the center insulator and run it back to an antenna tuner with a balanced output. Attach coax between the tuner and the radio and you’re in business on several bands!
For less than the price of an entry-level amplifier you can buy a multiband beam antenna and a decent rotator. This dynamic duo, mounted reasonably high, will offer a 5 to 7-dB steerable improvement to your signal. Remember Amplifiers only boost your transmitted signal and do nothing to improve reception. By rotating a directional antenna you can often achieve a double-whammy—boosting the signal you’re trying to receive while attenuating signals that are unwanted. For example, if I’m working a European ham from my Minnesota QTH, a potentially interfering signal from an op in Florida—located in the side null of my directional antenna—may drop 25 dB or more! The difference, more than 30 dB of signal enhancement, could never be achieved by a lone amplifier.
On SSB, learn the correct use of your rig’s speech processor. There’s another 3-dB (or more) improvement, this time in the modulation department! No purchase necessary!
Aftermath
So, after looking at the cold, hard facts, do antennas win out over amplifiers at your shack? Or will your operating table soon be sporting some heavy iron? As always, the choice is yours.
Amplifiers do have their uses—especially after you’ve tweaked your antenna farm. Add a 10-dB amplifier to a 7-dB beam antenna and you’ve got a whopping 17-dB improvement in signal strength! That will put you on the map—especially when the minimum necessary power required to communicate calls for maximum smoke. And when conditions are poor an amp may make
November QST: HF Amplifiers versus Antennas—One Ham’s Opinion - Page 4 ARRL 1998 QST/QEX/NCJ CD C i ht (C) 1999 b Th A i R di R l L I
the difference between being heard and being lost in the noise.
As long as it’s confession time, let me come clean.... Most of my operating over the past 23 years has been at QRP or barefoot power levels, but I’ve used an amplifier every now and then.
The first was one that I built myself from scavenged parts. I was seduced by the possibility of a glowing 4-400A transmitting tube, and I was trying to work DX on 80 meters with a poor antenna.
The amplifier helped me put a few difficult QSOs in the log, but collateral considerations forced me to abandon my glowing metal and glass monstrosity. The 150-pound amp was collapsing my operating desk, and its draw from the 120-V mains was overwhelming! I could only use it in the wee hours when everyone else was in bed....
After I put up a decent 80-meter antenna, I never looked back. Given the choice, I’ll take a "killer" antenna instead of a "rock crusher" any day! How about you?
S Meters and Radio Lore
Something needs to be said about S meters: With a few exceptions, they’re inaccurate, nonlinear and of dubious calibration!
Each S unit on a typical S meter is supposed to indicate a 6-dB increase in the strength of a received signal. But it probably doesn’t. Or it might—at one frequency on one band (or a few frequencies on a few bands). On other frequencies and modes, however, it might provide readings that are way out in left field.
S meters appeal to our senses and to our need to categorize and stratify things in our environment. They can be useful, but we shouldn’t rely on them for precise measurements. That’s what your brain is for. Use it and forget the bouncing needle!—NT0Z
When Less is More
Now that you’ve seen that it takes a whopping amount of extra power to make a noticeable difference in received signal strength, you might be wondering whether the cold equations work in the other direction—and they do!
If you have an okay signal with 100 W, you’ll likely have a workable signal with 25 W, or even 5 W. That’s the Holy Grail of QRP (low power) operation. The power output numbers work, just like before, in reverse.
Let’s say that you have an S9 signal with 100 W output. Cutting your power to 50 W provides a 3-dB decrease in strength. Cutting power to 25 W adds another 3-dB reduction. Therefore, going from 100 W output to 25 W output has reduced your received signal strength by 6 dB—only 1 S unit! By drastically cutting your power output, your signal has dropped from S9 to S8! That’s not a big deal!
Dropping from 100 W to 10 W is a 10-dB reduction—less than 2 S units. Dropping to 5 W, the commonly accepted threshold for QRP operation, totals 13 dB—just a smidgen more than 2 S units. Your signal will go from S9 to about S7! Again, not a big deal!
Add a decent directional gain antenna to the QRP equation and you’re back in the old ballpark—while running a lot less power. That’s QRP. And it’s a lot of fun.—NT0Z
  #2
Old 08-12-2007, 07:14 AM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt is on a distinguished road
Default
All good and true info.I run just 100 watts and for the most part if I hear a station I can be heard bt that sttion. The only times I wish I had more power is sometimes on 80 and 160m where it is hard to get a decent antenna and when there is a DX pile up.Everyone that has an amp uses it to work the rare DX station whether they need the extra power or not. Usually in those cases you actually do need the extra power,not to carry the distance, but to be heard over the idiots yelling out their callsigns constantly with all knobs to the right mentality.
  #3
Old 08-16-2007, 07:55 PM
KingCobra_CDX882 is on a distinguished road
Default
It is always best to upgrade your antenna system
(as best you can)
usally it is cheaper
usally it works better then a amp-linear
as example
on VHF and UHF
my friend and i have exact same dual bander radio
( Icom ID-800H )
He cloned my his radio to mine (i wasnt used to using D-Star )
the cloning puts in memory the frequency's and power levels
upon hooking it back up to my antenna system
i hit all the same repeaters he was able to
but....i noticed he had every channel (repeater) set to high
where i reset all but 3 or 4 of over 300 repeaters to low power
his high power that was needed was 50/55 watts
where i needed simply low power of 5 watts
difference being
i had higher gain antennas
as well as mounted 30 to 35 ft higher
also i am using heliax feedline to his lesser coax
So yes
antenna system is best to work on the most
reduce power when not needed
(but isnt how ham ops should use ham radio)
same holds true of HF obviously
is simply seen and realised much quicker with VHF and UHF
  #4
Old 08-16-2007, 08:16 PM
Default
Upgrading the antenna system also improves you receive by the same amount as your transmit,something an amplifier can not do.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
