Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > General Ham Radio Discussion
Amateur Callsign Lookup
Enter Callsign:
Icom IC-2720
Reply
  #1
Old 12-15-2007, 06:15 PM
Fdtrucker's Avatar
Fdtrucker is on a distinguished road
Default Icom IC-2720
Hello,
I have an Icom 2720 that developed a transmitting problem. It transmits less than 1 watt of power on both uhf and vhf bands no matter what power setting it is on. Everything else works fine except for this problem. I think it might be the driver or the finals. My question is: has anyone had any similar problem with this rig? Or any solutions..
Brian
__________________
Flyin' Brian CDX 1700
  #2
Old 12-15-2007, 08:10 PM
Senior Member
park is on a distinguished road
Default
Yes, myself five years ago and 1000's of other people. This radio has a history of this.
__________________
Everyone drives like crap but me.
  #3
Old 12-17-2007, 11:01 AM
Moleculo has disabled reputation
Default
I have that radio and had the same problem earlier this year. The problem is the driver. Icom will sell you a new one for fairly inexpensive if you want to put it in yourself. Or, they charge you around $80 (I think that's what it was) to do it for you. At the time I didn't know that it was just the driver that goes out, so I sent it in. If it happens again, I'll just fix it myself. If you do decide to send it to Icom, their turnaround time is pretty quick.
BTW, I believe the most likely cause of this problem is transmitting with a high SWR. I know there are a bunch of pages out there speculating how to "Fix" this issue, but I haven't seen anything that worked 100% of the time. It happened to me when I accidentally keyed the radio on high power setting with the coax unplugged.
  #4
Old 12-17-2007, 11:14 AM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt is on a distinguished road
Default
Mole, I would think a high SWR would take out the final amp and not the driver. Are you sure it is the driver? Usually those radios have an RF module that is a self contained driver and final in one package that only takes a few hundred milliwatts input. I lost the final in my Icom IC-2000H several years ago and all it would do was about 1/2 watt. Come to find out Icom failed to put enough,or any, heatsink compound on the output module at the factory.that was a common problem.
  #5
Old 12-17-2007, 01:03 PM
cyclops1970's Avatar
Gay Nazi Liberation Party
cyclops1970 is on a distinguished road
Default Re: Icom IC-2720
Quote:
Originally Posted by Fdtrucker
Hello,
Brian
I remember seeing something about repairing VHF modules somewhere on the internet...pretty much you popped the cover off of the module and reheated a solder trace that formed a stripline on the beryllium substrate.
  #6
Old 12-17-2007, 04:40 PM
Beetle's Avatar
Senior Member
Beetle is on a distinguished road
Default
Quote:
Wouldn't it work better if you put it in the radio? :shock:
  #7
Old 12-17-2007, 05:22 PM
Default
I would think that a high SWR would blow the final also, but I'm sure it was the driver they replaced. If you search around on the internet, you'll see that's the main issue almost everyone has on this rig. Maybe the high SWR was just coincidental in my case?
  #8
Old 12-18-2007, 07:34 AM
Fdtrucker's Avatar
Quote:
Originally Posted by cyclops1970
Hello,
Brian
So the stripline in the module could be the problem? Does this act like a fuse? I dont think I had an swr problem. I have been running another radio in it's place no problems for 2 months now no issues.
__________________
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
