Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > General Ham Radio Discussion
Amateur Callsign Lookup
Enter Callsign:
Wow...I'm stoked.....
Reply
  #11
Old 02-13-2009, 03:08 PM
WX2MIG's Avatar
Still Alive & Well
WX2MIG is on a distinguished road
Default
Quote:
Originally Posted by moleculo View Post
Now you got the HF bug. It's so much fun just stringing some wire up and getting on the air.
Do you have an antenna tuner? If so, you might want to consider replacing that coax with ladder line and just using your 40m dipole on all the bands below it. The losses will be negligable and then you don't have to worry about changing antennas.
Mole...just won a Kenwood AT-130 antenna tuner on eBay, it's the matching unit to this TS-130S. I don't believe it has the capacity for a balanced line feed since the description stated that it has 4 SO-239 connectors for 4 different antenna feeds....
Are you telling me that with a coax feed I won't be able to tune a 40m dipole to work on 20m...or any other band......????
That would suck.....
__________________
37OH - SSV - O773H
Worldwide Radio Forum
  #12
Old 02-13-2009, 05:57 PM
Senior Member
ajm1571 is on a distinguished road
Default
you should be able to tune 20m on a 40m antenna that is coax fed. Don't quote me on that, but it should work.
__________________
Allen
CDX015
2RT015
QS015
015 from Michigan
KD8FXB
Kenwood TS430s Maco 3's, A99, 80-10 balanced wire and a 20m vertical dipole
" LIFE'S A B**CH, DEAL WITH IT"
  #13
Old 02-13-2009, 08:24 PM
Beetle's Avatar
Senior Member
Beetle is on a distinguished road
Default
Quote:
Define "work".
You might make the transmitter think it's looking into a good match, but the SWR downstream from the tuner is going to be in the many hundreds, if not thousands, of ohms, and you'll still have a ton of loss in the coax. If the length of the coax isn't too great, this might be acceptable to you. 20:1 is not out of the ballpark for a 40 meter antenna on 20 meters. Figuring a 50 foot length of RG-213, the loss is "only" about 2.6 dB @14 MHz, which is still almost half your power.
Don't forget that you'll have the same losses on receive.
__________________
If you're like everybody else,
you're about average.
73 de K7KBN
  #14
Old 02-13-2009, 09:19 PM
Lazybones1222's Avatar
Senior Member
Lazybones1222 is on a distinguished road
Default
Quote:
Originally Posted by Beetle View Post
Define "work".
Will not the using REAL ladder line be minimal compared to coax?
  #15
Old 02-13-2009, 10:11 PM
Beetle's Avatar
Senior Member
Default
Quote:
Sure it will, and that's the point. Coax is great feedline IF the feedpoint impedance matches (or approximates) the characteristic impedance of the coax. Typical dipole in free space = 70-75 ohms. Same dipole at realistic height = 50-60 ohms.
Both of these figures are at the frequency at which the dipole is 1/2 wavelength, which we've established as 7 MHz. At 2x that frequency, the feedpoint impedance is going to be very high. Same at 4x, 6x, and other even multiples. At ODD multiples, say 3x (21 MHz; 15 meters), the feedpoint impedance will again be low, and 40 meter, coax-fed dipoles are widely used on 15 meters with good results.
It's interesting to note that even at even multiples of the frequency, with SWR around 20:1, a dipole is still resonant. An antenna analyzer at the feedpoint will confirm that.
A "resonant" antenna doesn't necessarily have a low SWR.
__________________
73 de K7KBN
  #16
Old 02-13-2009, 10:46 PM
Senior Member
Default
Define "work".
that answered my question that was within a statement lol
__________________
Allen
CDX015
2RT015
QS015
015 from Michigan
KD8FXB
  #17
Old 02-13-2009, 11:18 PM
Senior Member
moleculo has disabled reputation
Default
No, I didn't say that. You should be able to tune it with coax feed line and will also have fun talking too. But (as Beetle described very well) the feed line loss can be significant doing it that way which will severly affect your TX/RX signal strength. Using ladderline minimizes those losses to next to nothing . It's also so cheap that it really makes it worth considering. There are some issues you have to consider, however. You can't just strap it to the side of your antenna mast like coax. You must figure out a way to make it "stand off" from the mast and also need to run it at 90 degrees when you need to cross other metal surfaces (like rain gutters). If your exterior walls are made of stucco and chicken wire, you really need to get it away from that a bit. Other than those few issues, it's a piece of cake. You say your tuner only has S0-239 connectors? No problem; use a balun. You don't want to deal with the stucco/chicken wire/rain gutter issue? Run a 10' length of coax out of the shack, then attach a balun and run the ladder line the rest of the way.
There are a lot of ways to skin this cat.
  #18
Old 02-14-2009, 02:35 AM
Senior Member
BJ radionut is on a distinguished road
Default AT-130 tuner
Tony: Are you sure, you purchased the KWD AT-130 tuner?
This tuner has only ONE coax in/out...unless it has been modified.
The tuning range is really pretty slim. This tuner is made to only tune coax antennas with about a 3 or 4 swr or smaller (about 200 Ohm range) nice little unit for mobile/base unit...but for example using a 40m dipole it should be able to tune the entire 40m band... and then tune your 40m antenna on 15 meters. This tuner may not have the range to tune your 40m on 20m...
I was going to email you the manual but did not find your AD on Qrz or here...let me know if you need it and I can send it along...
Glad your enjoying the new rig...have fun...hope to meet you "In the Air"
I'll be on 3865 Sunday morning...if I do not have to work. I run that mobile early in the AM from about 6 Am EST to around 7 AM also...
All the Best
BJ
PS: Look for a Shure 444D or M/desk top... great Mic for that rig. I have also used a Shure S58 and couple other studio mics on them that work well. Never much cared for the factory hand mic but that's me.
__________________
Real Radios Glow in the Dark
Antennas are 95% of your signal, Your wattage is the Balance
Nothing is more FUN than busting a pile-up with 5 WATTS or LESS
  #19
Old 02-14-2009, 05:21 AM
Senior Member
Default
65 feet of wire, some of this ladder line, and a tuner - and you are good to go. This ladder line is the snaizzle. Or just look how he did it and make your own. I will never go back to coax (in most applications).
real ladder line :
http://www.w7fg.net/ladder/totower.JPG
Ladder line photos & comments
  #20
Old 02-14-2009, 05:54 AM
Senior Member
hookedon6 is an unknown quantity at this point
Default
Quote:
Originally Posted by N2ITH View Post
...I start spinning the dial on the 20m band, hear a bunch of QSO's in progress, then on 14.209.0 I hear a station with a funny sounding call sign calling out "CQ DX North America"....I return his call... I'm Stoked.......
being "stoked" is one thing,....
being out of band is entirely another matter
just sayin
Reply
Bookmarks
Tags
20 meters, 40 meters, dipole, ladder line
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
