Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > General Ham Radio Discussion
Amateur Callsign Lookup
Enter Callsign:
2009 Dayton Hamvention Coverage
Reply
LinkBack (58) Thread Tools Display Modes
  57 links from elsewhere to this Post. Click to view. #1
Old 05-15-2009, 08:39 AM
Senior Member
moleculo has disabled reputation
Default 2009 Dayton Hamvention Coverage
Happy_Hamer (Bill) & I arrived this morning early at the 2009 Dayton Hamvention. We'll continue to update this thread with pics and interesting things as we have time.
Here are a couple of pictures of new Radios being shown. Details to follow...
Here's the announcement from Kenwood about their new HT (no radio shown)
Here's the announcement of the new Kenwood HF Transceiver:
New Alinco 1.2 Ghz HT
This is the only 1.2Ghz HT on the market right now. It's also full duplex, which means it will work great for working Satellites
Bill with the Kenwood girl:
More to follow...
Worldwide Radio Forum
  #2
Old 05-15-2009, 12:37 PM
Senior Member
Default FlexRadio 3000
Here's a few more quick shots of interesting things:
The brand new Flex 3000 outside case
Inside Flex 3000:
FlexRadio software:
A couple of quick points that about the Flex 3000: They said that the case is made of steel and is so strong that even Bill could stand on it. If you saw his pic above, you'll understand why we didn't take them up on the challenge.
This radio and software is truly amazing. The software is showing a real time band spectrum graph & waterfall....not a band sweep like other radios and software. You can click on the peak that you want to listen in on and go to that frequency real time. To change the filter width, you just click and drag the screen on the graph. This makes will make contesting and dealing with DX pileups really easy. The radio sells for $1599 and the specs are on par with competitors from Icom or Yaesu that sell for a whole lot more. These guys said they would take on a Icom 7600 any day.
edit: Here's a pic I just found of the PA section of the Flexradio 3000:
And another shot of the application that "drives" the Flexradios:
  #3
Old 05-15-2009, 12:43 PM
Senior Member
Default JetStream 200Mhz mobile
Here's the new Jetsream 220Mhz mobile. This is the only one of these that hasn't been sold to someone in the U.S. They're expecting more any day.
Jetstream has a lot of products that are available now. The secret that Diamond doesn't want anyone to know is that they are exactly the same products as Diamond products but 1/2 the price. Everything from the SWR/Power Meter, HT antennas, Antenna switches, base antennas, are exactly the same...but 1/2 the price. For example, the Diamond 2m/220/440 antenna that everyone likes for their Kenwood THF-6a or Yaesu VX-8r is also branded as a Jetstream product and is $24.95
  #4
Old 05-15-2009, 01:03 PM
Wire Weasel's Avatar
Psycho Twinky
Wire Weasel is an unknown quantity at this point
Default
Alright Bill & Big M, I know you guys are going to have a blast. Never made it to Dayton, always too fer away for this po' ol' country boy to travel to from way down south.
Keep the pics and stories coming. Are there Icom Girls this year? Me wants to know this. Me want pictures
__________________
Supplying All Your Wire and Weasel Needs Since 1869 * All Orders Come With A Free Pack Of Vazomyne For Sustained Performance
gal dx 94hp imax .64, gpk / con 4300hp, 102 stainless
  #5
Old 05-15-2009, 04:49 PM
QRN's Avatar
QRN QRN is offline
Administrator
QRN is on a distinguished road
Default
Quote:
I knew it!! I could tell from the looks of their SWR/power meters that they were the same. Thanks for confirming it. Keep the info and pix coming Tim and Bill. One day I hope to make a pilgrimmage to Dayton before I die.
__________________
Education is what you get from reading the fine print. Experience is what you get from not reading it.
  #6
Old 05-15-2009, 05:33 PM
Senior Member
Default Icom
Since Wire Weasel asked about Icom
Here's Bill with an Icom girl:
Here's the Icom 7800 that has been out for a while. Bil liked to go around and change all the radios to CB 19 and put them on AM mode
Here's the new Icom 7600
You'll notice that it has a USB port on the front. It also has one on the back. If you buy a 7600, they throw in a USB keyboard also. Here's the dumb part: You can't use this to connect to your PC for rig control. You still have to use the old serial interface that Icom has included in their HF rigs for some time. WTF?? The Icom guy said that since it has updateable firmware (via the USB) they may do a firmware update to support that at some point. I reminded him that unless the old serial and USB are on the same bus internally, that will never work. And if they were on the same bus, they could have just as easily made it work via USB already, so that means it probably isn't on the same bus and won't ever work. He said, "oh yeah."
EDIT: We went to another Icom booth and asked another Icom rep the same question about the USB ports. We told him what the other Icom guy said. This guy said that what the other guy told us wasn't correct. He said you CAN use the rear USB port to connect to your PC. We all looked through some of the Icom documents they had and verfied that this really is the case. It looks like the first rep was a little confused about how the USB ports are used.
Here is the new Icom DStar rigs that are companion products:
Here's a closeup of the ID-880h:
It's a dual band DStar 2m/440 mobile with 1052 memories, wide receiver, DTMF mic, and a few other things. It's pretty small and the face plate seperates like most mobiles. Price range is about $500.
Here's the newest DStar Icom HT:
It is replacing the IC-91AD, also a 2m/440. It has 1000+ memories, continuous 0.5mhz-1Gz receive and includes GPS. DStar is standard, not optional. Price is about $450.
  #7
Old 05-15-2009, 05:41 PM
Senior Member
Default
This is Fred.
Fred is holding the new Alinco 1.2Ghz HT...the only 1.2 Ghz available.
Bill asked Fred if he wanted his picture on the internet with this neat HT.
Fred said, "YeaAAAHhh"
I took the picture and Fred wanted us to MAKE SURE we could see his callsign in the picture.
Yes Fred, we can see both your callsign and your name.
And since we promised your picture on the internet, here you go...
  #8
Old 05-15-2009, 05:56 PM
Senior Member
Default New Kenwood HF, HT
Back on the subject of the new Kenwood HT: They said that this will be replacing the TH-D7AG...that's right the one that Jay_in_the_Mojave disliked so much that he cut in half (see picture below)
Once again, here is the announcement:
And here is the new Kenwood HF/6m rig info: This will be the new HF rig to compete with the high end Icom and Yaesu:
And that's all the info we have on these new rigs. All they had was a couple of teaser posters and the info I just gave.
Anyway, here's what Jay thought of the TH-D7AG
  #9
Old 05-15-2009, 06:00 PM
Sonwatcher's Avatar
Senior Member
Sonwatcher is on a distinguished road
Default
Hi Fred !
Looks good guys !
__________________
http://www.haminfobar.co.uk
  #10
Old 05-15-2009, 06:38 PM
Senior Member
Default SuperAntenna PR-1 12vdc rotor
This item here is so new that it has never been on the internet before now. It's not even on Superanntennas.com. The prototypes pictured here just came back from manufacturing on Tuesday, 3 days ago. This is a new 12vdc antenna rotor. He was running this on a 9 volt battery for demo purposes. You can tell how small this is because Bill is holding it in his hand. Vern, W6MMA (the maker) had this mounted on one of his YP-3 break down Yagis above.
This rotor has a 1000:1 gear reduction in it. Here is the controller:
This thing has variable speed and an LED position display. It really is a neat little rotor...perfect to use with rotatable or portable dipoles and other break down or light-weight antennas.
Estimated price is $249
Here is a quick video clip of the rotor controller. The speed on the rotor has been turned way down in this clip:
Reply
Bookmarks
Tags
2009 dayton hamvention, 220 mhz, alinco 1.2 ghz, begali key, begali paddle, biddipole, capacity hat, cw keyer, dayton 2009 hamvention, ic-7600, icom ic-7800, icom ic-80ad, jetstream, super antenna yp-3, tophat, w2ihy
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/general-ham-radio-discussion/34050-2009-dayton-hamvention-coverage.html
Posted By For Type Date Hits
TS-480‚ðŒê‚è‚Ü‚µ‚傤@Part2 This thread Refback 09-12-2009 06:58 PM 1
S50LEA • Poglej temo - Kon?no! Prihaja nova Kenwood HF postaja! This thread Refback 08-26-2009 01:50 PM 1
š™š™@ƒnƒ€ƒtƒFƒA2009@™š™š This thread Refback 08-20-2009 07:49 PM 1
ARI Fidenza This thread Refback 08-20-2009 07:36 AM 1
š™š™@ƒnƒ€ƒtƒFƒA2009@™š™š This thread Refback 08-19-2009 01:04 AM 2
š™š™@ƒnƒ€ƒtƒFƒA2009@™š™š This thread Refback 08-17-2009 06:22 PM 1
???????? [????????????] This thread Refback 08-17-2009 03:09 AM 1
š™š™@ƒnƒ€ƒtƒFƒA2009@™š™š This thread Refback 08-16-2009 03:20 PM 2
š™š™@ƒnƒ€ƒtƒFƒA2009@™š™š This thread Refback 08-16-2009 02:17 AM 2
???????????? This thread Refback 08-08-2009 08:55 AM 1
???????? [TS-480????????Part2] This thread Refback 07-30-2009 07:58 AM 1
ARI Fidenza This thread Refback 07-14-2009 06:41 PM 1
Dishtronix dx2400l1 This thread Refback 06-17-2009 07:04 PM 1
????? - ?????de JO7MJS (also JA8RXD?since 1973) This thread Refback 06-11-2009 11:07 PM 30
S50LEA • Poglej temo - Kon?no! Prihaja nova Kenwood HF postaja! This thread Refback 06-05-2009 11:37 AM 1
S50LEA • Poglej temo - Kon?no! Prihaja nova Kenwood HF postaja! This thread Refback 06-05-2009 01:51 AM 1
S50LEA • Poglej temo - Kon?no! Prihaja nova Kenwood HF postaja! This thread Refback 06-05-2009 12:08 AM 2
S50LEA • Poglej temo - Kon?no! Prihaja nova Kenwood HF postaja! This thread Refback 06-04-2009 04:03 PM 1
S50LEA • Poglej temo - Kon?no! Prihaja nova Kenwood HF postaja! This thread Refback 06-04-2009 03:41 PM 1
S50LEA • Poglej temo - Kon?no! Prihaja nova Kenwood HF postaja! This thread Refback 06-04-2009 01:35 PM 1
S50LEA • Poglej temo - Kon?no! Prihaja nova Kenwood HF postaja! This thread Refback 06-04-2009 01:30 PM 2
S50LEA • Poglej temo - Kon?no! Prihaja nova Kenwood HF postaja! This thread Refback 06-04-2009 07:21 AM 2
??????????????????????: ??????.... by SEN This thread Refback 06-02-2009 07:45 AM 1
S50LEA • Poglej temo - Kon?no! Prihaja nova Kenwood HF postaja! This thread Refback 06-01-2009 11:04 PM 1
??????????????????????: ??????.... by SEN This thread Refback 05-31-2009 06:02 PM 11
ARI Fidenza This thread Refback 05-30-2009 02:24 PM 1
ƒPƒ“ƒEƒbƒhD‚«‚ÈlW‚Ü‚ê This thread Refback 05-29-2009 08:57 AM 1
TS-480‚ðŒê‚è‚Ü‚µ‚傤@Part2 This thread Refback 05-26-2009 07:48 AM 3
yamada_radio_clinic: 2009?5? This thread Refback 05-26-2009 05:50 AM 3
yamada_radio_clinic This thread Refback 05-25-2009 08:36 AM 1
?????????????(????????????) - ????????? This thread Refback 05-24-2009 09:22 PM 15
_texto This thread Refback 05-24-2009 04:46 PM 386
????????? This thread Refback 05-24-2009 01:05 PM 4
TS-480‚ðŒê‚è‚Ü‚µ‚傤@Part2 This thread Refback 05-24-2009 08:24 AM 3
ARI Fidenza This thread Refback 05-23-2009 12:47 PM 1
TS-480‚ðŒê‚è‚Ü‚µ‚傤@Part2 This thread Refback 05-23-2009 07:07 AM 8
ƒPƒ“ƒEƒbƒhD‚«‚ÈlW‚Ü‚ê This thread Refback 05-20-2009 05:53 AM 2
yamada_radio_clinic: ??????? This thread Refback 05-20-2009 05:13 AM 53
??????KENWOOD: yamada_radio_clinic This thread Refback 05-19-2009 09:30 PM 141
yamada_radio_clinic This thread Refback 05-19-2009 08:27 PM 64
Dayton TODAY 5-15-2009 - QRZ Forums This thread Refback 05-18-2009 02:17 PM 3
Inbox: 35 messages unread - woody4@afo.net - 52.1MB (52%) - 05/18/2009 11:49:04 am -0500 - iso-8859-1 - Open WebMail (+) This thread Refback 05-18-2009 10:49 AM 1
2009 Dayton Hamvention Coverage This thread Refback 05-18-2009 05:32 AM 1
S50LEA • Poglej temo - Kon?no! Prihaja nova Kenwood HF postaja! This thread Refback 05-18-2009 01:09 AM 3
Pics from Hamvention 2009 - KSCCW.com Forum This thread Refback 05-17-2009 04:01 PM 41
Pics from Hamvention 2009 - KSCCW.com Forum This thread Refback 05-17-2009 03:18 PM 69
S50LEA • Poglej temo - Kon?no! Prihaja nova Kenwood HF postaja! This thread Refback 05-17-2009 01:19 PM 10
S50LEA • Poglej temo - Kon?no! Prihaja nova Kenwood HF postaja! This thread Refback 05-17-2009 09:26 AM 3
Dayton TODAY 5-15-2009 - QRZ Forums This thread Refback 05-17-2009 09:13 AM 3
ARI Fidenza This thread Refback 05-17-2009 08:36 AM 70
S50LEA • Poglej temo - Kon?no! Prihaja nova Kenwood HF postaja! This thread Refback 05-17-2009 08:13 AM 256
Dayton TODAY 5-15-2009 - QRZ Forums This thread Refback 05-15-2009 10:02 PM 7
Enjoying Dayton - QRZ Forums This thread Refback 05-15-2009 08:27 PM 3
Enjoying Dayton - QRZ Forums This thread Refback 05-15-2009 07:58 PM 17
Anyone else here in Dayton - QRZ Forums This thread Refback 05-15-2009 07:22 PM 1
Dayton - Page 4 - QRZ Forums This thread Refback 05-15-2009 07:11 PM 26
Anyone else here in Dayton - QRZ Forums This thread Refback 05-15-2009 06:49 PM 58
Dayton TODAY 5-15-2009 - QRZ Forums This thread Refback 05-15-2009 06:11 PM 290
Powered by vBulletin®
