Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > General Ham Radio Discussion
Amateur Callsign Lookup
Enter Callsign:
Ebay power supply
Reply
  #1
Old 05-20-2009, 02:47 PM
DragoSapien's Avatar
KF5AEJ
DragoSapien is on a distinguished road
Default Ebay power supply
I was just wondering if anyone has bought any of the pyramid brand power supply's. Is that a good brand or should I keep looking.
Worldwide Radio Forum
  #2
Old 05-20-2009, 03:39 PM
Senior Member
moleculo has disabled reputation
Default
They're fine. They're not as "rugged" as some of the others like Astron, but I have a 14amp one if been using for probably 9 years with zero problems.
You should also look in the Forum Store if you want a new one (shameless plug ). I have those at very competitive prices for forum members...even better than what I can do for other products.
  #3
Old 05-20-2009, 09:12 PM
BOOTY MONSTER's Avatar
Senior Member
BOOTY MONSTER is on a distinguished road
Default
heres a link to a couple of reviews of the pyramids . pyramid and pyle are the same thing inside , just cosmetic differences on the outside . pyramids numbers in their name refers to the PS peak amperage , pyles number refers to its contious amperage .
Pyramid PS-36KX Power Supply Review
Pyramid PS-14KX
__________________
2018 Extreme Mic
Uniden Washington
Palomar 225
Astron RS-35M
Astatic 700
Homebrew .64 WGP
  #4
Old 05-20-2009, 09:35 PM
unit_399's Avatar
BIGSTRAPPER
unit_399 is on a distinguished road
Default
Moleculo -
What pass transistors do the Pyramids use ?? Also how many pass transistors in your 14 amp supply ??
- 399
  #5
Old 05-20-2009, 11:42 PM
Senior Member
Default
Well, I don't have any schematics handy, but a quick search showed that they use LM723, 2N3055 or 2N3177 NPN pass transistors. I'm not sure shich one mine uses as I've never had a reason to open it up to see.
  #6
Old 05-21-2009, 12:35 AM
74IN's Avatar
Supporting Member
74IN is on a distinguished road
Default
LM723 is a transistor?
I thought it was a regulator IC,
__________________
XDX74
  #7
Old 05-21-2009, 12:37 AM
Senior Member
Default
Oops...yes you're right...
  #8
Old 05-21-2009, 12:44 AM
ajm1571 is on a distinguished road
Default
i have a ps 36kx powa supply an it works great! Never had a problem with it yet an it's few yrs old. runs the TS430 with NO probs. just my .02
__________________
Allen
CDX015
2RT015
QS015
015 from Michigan
KD8FXB
Kenwood TS430s Maco 3's, A99, 80-10 balanced wire and a 20m vertical dipole
" LIFE'S A B**CH, DEAL WITH IT"
  #9
Old 05-21-2009, 06:33 AM
WX2MIG's Avatar
Still Alive & Well
WX2MIG is on a distinguished road
Default
Don't know if this helps or not, but I run my entire shack off of one Samlex SEC-1223, that's an IC-2200H, the Uniden VHF Marine, and the TS-130S all at the same time. Since I only transmit on one radio at a time I've never had reason to believe that I'm over burdening this power supply.
I know several ham's that insist on using super high amprage power supplies, and unless you're running a 200 watt transceiver, or a solid state amp that requires 12 vdc, it just seems like over kill.....
__________________
37OH - SSV - O773H
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
