Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > General Ham Radio Discussion
Amateur Callsign Lookup
Enter Callsign:
A lucky day!!
Reply
  #11
Old 10-13-2009, 09:14 PM
Train's Avatar
Location: In the Woods where you can bearly get out with the cell .
Train is on a distinguished road
Default
Nice radios . Back when he had a ham outing with Generals and Extras there and hear them on 7 mhz and it was amazing what you could do on 7 mhz and go from Florida to Texas .
Worldwide Radio Forum
  #12
Old 10-14-2009, 09:11 AM
Radio Tech's Avatar
Radio Operator
Radio Tech is on a distinguished road
Default
Quote:
Originally Posted by QRN View Post
As for the 2 watts from the F model, check the driver tube as well as the finals and make sure the grid switch is not turned OFF. That allows just the driver power out to the antenna to operate a transverter. (I think the 101 has that function.I know my Kenwood TS-820S does.)
QRN
I was thinking about this today.
I have not had any time to work on these.
But last night I looked in the back to be sure the Acc plug was in the rig. The 101 does not have a switch on the back other than the front panel heater switch. If the plug is not in it will not produce power.
I do remember seeing a RCA jack hanging out the back of the plug. So going to check that out tonignt.
  #13
Old 10-15-2009, 04:01 AM
Radio Tech's Avatar
Radio Operator
Default
Last night I pulled the ACC plug off the F and put another one on.
Sure enough I got full out put on 40 and 80 meters. Less thn 20 watts on all other bands. The S-meters works but not in PO, IC or ALC. So got to trouble shoot the reason power is down on other bands and the meter circuit.
  #14
Old 10-15-2009, 08:46 AM
Captain Kilowatt's Avatar
Administrator
Captain Kilowatt is on a distinguished road
Default
Sounds like it's on the road to recovery already. I wasn't sure about the Yeasu's having the grid cut-off switch like the Kenwoods do but it was worth a look.It's always nice when a "broken" radio is easily repaired. When I bought my TS-820S it came with the external vfo VFO-820 as well. The seller told me up front that the external VFO did not work and he thought that he blew a transistor in it when he unplugged the interface cord with the power on and saw a small spark.The radio worked great with the internal VFO but needed the interface cable plugged in to work unless I jumpered the jack on the back. I got the radio home and opened up the VFO and while I was poking around I found a bad connection inside the cable where it connects to the jack. He must have broken the tiny coax cable that carries the VFO signal back to the radio.It was a pain to solder as it was so tight but after a couple minutes I had a fully operational external VFO allowing me to work split.
__________________
Front/back ratio comes from the antenna. Forward gain comes from the wall socket.
  #15
Old 10-15-2009, 06:41 PM
Radio Tech's Avatar
Radio Operator
Default
Now thats pretty good. Strange that things will break and folks will sell it . Most today lack the know how when it comes to this stuff.
Glad that one worked out for you.
I got on 80 meters and was tuning around and heard a couple of guys chatting. After they finished I threw my call out using the F. One came back to me and said I had good audio and wanted to know what I was talking on. He was in Texas.
If it sounds good now I wonder how it is going to sound when I get it fixed. Not sure how much bias I have but I did turn it way down.
Not going to get much done this week end. I have to work in the morning and repairs Saturday. I am suspose to be on a week lay off next week but a guy wanted to switch with me. We are required to take a week of lay off a month untill the end of the year. But one line is running and they work a lot of OT. So I will be working. Oh well.
So much to do so little time.
  #16
Old 10-19-2009, 04:12 AM
Radio Tech's Avatar
Radio Operator
Default
Well, yesterday I had a chance to play arounf with the E model. Took it apart and cleaned the heck out of it. Soldered up a few joints. This radio would come on, the meter and dail lights would light up, but the VFO light was out. Also it had no TX or RX.
After the clean up the rig transmits full power on all bands. It also receives on all bands but the RX is down a bit. Most likely a proble with the FET.
I want to find the original 11 meter crystal and put back in the 11 meter slot. There is a 12 meter crystal in there now. I am going to take that out and put in the F.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Field Day June 27-28 HR1/K2LCT General Ham Radio Discussion 0 06-26-2009 10:15 AM
ANNUAL ARMED FORCES DAY CROSSBAND EVENT moleculo Announcements & Open Forum 1 04-21-2009 06:58 AM
Get Ready for ARRL Field Day 2009 ARRL ARRL Updates 0 03-23-2009 06:40 PM
Field Day Station Locator Service Returning for 2009 ARRL ARRL Updates 0 02-23-2009 07:11 PM
Valentine's Day Give Away Drawing! moleculo Announcements & Open Forum 41 02-14-2009 09:26 PM
Powered by vBulletin®
