Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > General Ham Radio Discussion
Amateur Callsign Lookup
Enter Callsign:
Help on vfo problem FT100d
Reply
  #1
Old 10-20-2009, 08:22 PM
Junior Member
KE7GRO is on a distinguished road
Default Help on vfo problem FT100d
Hello I have a ft100d and the vfo shaft came out of the face. I disassembled the face and removed the vfo encoder/sending unit and disassembled the housing cover and the board inside the housing leaving a clear "splined" plastic refracting disc. I cleaned the old glue off the shaft hole, reinserted the shaft and epoxied it. I reinstalled everything exactly as it came apart with no problems. A sturdy fix BUT... The vfo worked- just backwards.. I need to figure why the vfo increases in frequency counter clockwise and decreases clockwise.
If anyone has some info on this I would appreciate the help, Thanks Eric.
Worldwide Radio Forum
  #2
Old 10-20-2009, 09:29 PM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt is on a distinguished road
Default
On the encoder there should be four wires,red,black,green, and white. The red and black are power. Leave them alone. The green and white wires are the output from the encoder.Reverse them and it should tune correctly. You may have crossed them up when reassembling the encoder.
__________________
Light travels faster than the speed of sound, this is why some people tend to appear bright, until they decide to speak.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Sirio turbo 3000 swr problem rekal CB Antennas 4 07-18-2007 06:49 PM
Cobra 200GTL recieve problem TonyV225 Tech, & Repair 4 08-13-2005 09:50 PM
New Antenna = Problem jdgee CB Band and CB Radios 6 04-07-2005 08:52 AM
SS 3900 TX/RX problem i think nay27uk Tech, & Repair 1 04-25-2004 02:02 PM
RCI 2995DX recieve problem Glazierman Tech, & Repair 1 12-31-1969 06:00 PM
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
