scare tactic ?  | |
11-06-2009, 10:05 AM
| | Senior Member | | Join Date: Aug 2009
| | Your analogy is wrong. It is closer to how hunters feel about poachers. Many hunters do not consider the game animals theirs, but take offense when someone who has not earned a game animal takes one. This has lead to some poachers being turned in and in one case a poacher was shot in the woods, by someone. IMHO, the police didn't investigate that murder, they just wrote it off as field justice. Who knows it could have been one of them who did the shooting. |
11-06-2009, 02:05 PM
|  | Senior Member | | Join Date: Aug 2005
| | The Real Analogy The real analogy is more like driving.
I have a licence to drive on our public roads. This is a granted privelage. If a non-licensed driver occupies the road, they may illegally interfere with my authorization to use a particular space at any given time.
That is all.
It is not like someone stealing my steak from my home!
I actually own that steak, no ham owns a frequency.
I have an inalienable right to that steak, nobody has an inalienable right to a frequency.
It is secured on my private property, Ham frequencies are not individually private, but are for the ham community. They are not property.
No government entity can issue authorization to the public to enter and use my property (althought hey may claim some sort of emminent domain, if need be).
Nobody has a "right" to amateur radio just like nobody has a "right" to drive an automobile. They are licenced privelages...
Not only is the steak analogy bad, it is utterly wrong -- and it just illustrates see dubya's flawed mentality. |
11-06-2009, 03:15 PM
| | Senior Member | | Join Date: Aug 2008
| | CB guys have no limits on power, bandwidth or channels. Hams do. Why hang out with boring hams when you can go anywhere in the spectrum and do whatever you want |
11-06-2009, 04:39 PM
|  | Senior Member | | Join Date: Dec 2008 Location: Silicon Valley CA, Storm Lake IA
| | Just Depends... Quote:
Originally Posted by HiDef CB guys have no limits on power, bandwidth or channels. Hams do. Why hang out with boring hams when you can go anywhere in the spectrum and do whatever you want  | I disagree - agreeably.
Hams can use power legally. CB'ers get fined. Also, Hams can talk on 1.8mhz all of the thru to 1.2ghz (and beyond); how's that for channels? CB's only have between 26.965mhz to 27.405mhz. Sure, you can use freq's above and below - but you run the risk of FCC biting you - as thse freq's are used by the US Gov't!!!
As far as 'doing what you want' - is nothing more than lack of understanding of the circumstances. If you start to interfere with someone - you will quickly find out when someone complains!
That's it!
__________________ What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9.
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770. "...The 444 in San Jose CA; the Central Gold Coast..." |
11-08-2009, 04:30 PM
|  | Member | | Join Date: Jul 2009
| | If they come up on 10 meters without a license, most likely they will run into my propagation beacon for experimental and educational purposes. Nice propagation beacon right near two truck stops. Good place for it. At least someone is listening to it and can learn from it. |
11-08-2009, 04:49 PM
|  | Administrator | | Join Date: Apr 2005 Location: Nova Scotia,Canada
| | My FT-857 has a beacon setting and can be set to operate as a beacon transmitter. So far I have let it run on 6m only but I like your idea of a 10m beacon. How about a 10m mobile propagation beacon next to a truck stop.
__________________ Front/back ratio comes from the antenna. Forward gain comes from the wall socket. |
11-08-2009, 04:57 PM
| | Quote:
Originally Posted by QRN My FT-857 has a beacon setting and can be set to operate as a beacon transmitter. So far I have let it run on 6m only but I like your idea of a 10m beacon. How about a 10m mobile propagation beacon next to a truck stop.  | I like that idea too. That's even better because it's mobile and makes propagation more defined on the other end. |
11-08-2009, 08:50 PM
| | Senior Member | | Join Date: Apr 2002
| | I like the idea of setting up a propogation beacon. But I don't know how to do it...would someone care to start a thread and enilighten us? |
11-08-2009, 09:03 PM
| | Quote:
Originally Posted by moleculo I like the idea of setting up a propogation beacon. But I don't know how to do it...would someone care to start a thread and enilighten us? | I have a digital voice and cw recorder built into the radio. I can put it in repeat or loop mode and tell it how long to leave gaps in between transmissions. Turn the receive volume down to 0 and let it go for as long as you want. Just make sure your fans are working because she will get hot. (hint hint) |
11-09-2009, 07:46 AM
| | Senior Member | | Join Date: Mar 2007
| | Quote:
Originally Posted by KD8LWX From what I have seen as a new ham, there are a couple different ways of dealing with someone who is on a ham freq and shouldn't be.
1. If it sounds like someone who is new or generally clueless, but trying to do the right thing hams will point them in the right direction. | Heh, don't forget, it's illegal to even acknowledge a station without an ID. Even "go away" is breaking the law. |  | | | Thread Tools | | | | Display Modes | Linear Mode |
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -7. The time now is 10:56 PM. |
