THE BEST WIRE ANTENNA
AE5RD
Reformed CB'er
May 4, 2005
136
62
In you're opinion which is the best wire antenna for 80, 40 and 20 meter ragchewing? I am using a homebrew G5RV. It performs well and excellent on 20 meters but I noticed my 20 meter aluminum dipole seemed to get a better signal on 20 than does my G5RV.
For rag chewing, I might have to vote for the loop, especially on 40 and 80 meters. I've also heard several people on a Super Loop (home made) and they were unbelievable loud on 80 meters. I'm not sure how well they would work on 20m, though.
The best antenna, no matter what it's made with, is one specifically made for the band of use.
Want a good 'all band' antenna? Boy! You have some decisions to make with that one! A 'fan' dipole, multiple 1/2 wave elements from the same feed point is probably about the 'best'/simplest/cheapest if you can string it up.
I like loops and ladder line and don't think using a good tuner is all that 'bad'. So a loop resonant on the lowest frequency you'll ever use normally works on a lot of other bands too (not all of them, but most). In general, the longest, tallest, biggest antenna you can accommodate for the space you have is the 'best' for you.
I'd love to be able to afford a couple of 'Stepper' antennas. Not that I'd ever buy them, I just wish I could afford them!
And just for grins, that G5RV was designed as a 20 meter antenna, that's where it was meant to work best. That it will 'work' on other bands is just incidental, and very over-rated.
Loop will work great on 40-80. I use a full wave loop cut for 3.80 and it works fine on 40. It hears great on 20 but I havent used it much for transmit.
If your gonna use the loop on 20 I would suggest lader line feed. Just 40-80 coax fed will do fine. Coax will work on 20 but will have losses.
A double extended zepp will provide more gain but will be bi directional."single band"
I agree a fan dipole is great. I ran one for years with 160-80-40 legs. Currently I like my loop better than anything I have used so far. I strictly rag shew no dx chasin.
In you're opinion which is the best wire antenna for 80, 40 and 20 meter ragchewing?...
you might want to research the NVIS type antennas.
they are great for ragchewing due to the high radiation angle and are simple to erect because they are close to the ground.
the DXer types call them "cloudwarmers", but they provide consistant signals out to about 800 miles radius or so with little QSB
I run a Buxcomm 80 to 6 meter off center fed windom in an inverted V set up...works better than I expected it to...80 40 20 meters that antenna is really nice..use a tuner but it dont work to hard,works good on 17 but tuner is a must...160 and 15 meters the tuner just dont like it
Wire antennas are a comprimize unless you cut an antenna for each band you are wanting to work..That takes alot of wire and feed line though
But I am happy with the antenna that I use,but make sure you have a decent tuner
I built and use a W5GI "Mystery Antenna". It works really well on 80, 40, 20, 17, 15, and 10. I don't need the tuner on 80, 40, or 20. It works on 12 and 6 also, I just don't really know how well yet. It ain't no "pileup buster", but I can usually get back to anybody I hear on it. Only about 102 feet long, which is also nice.
I have been having problems with my G5RV. I built it according to spec. Is the antenna supposed to load up on 14.150 without a tuner? I can't seem to get my swr down and I can't develop full power. I have an array of antennas. I might have to move the G5Rv somewhere by itself. And does the feeder line have to hang down straight?
... I've also heard several people on a Super Loop (home made) and they were unbelievable loud on 80 meters...
SUPER loop????? yee haw(y)
seriously,..... i don't think i've ever heard of one. do you have a link. i'm puttting up a loop this summer.
i have found sites with a "mini super loop",.... is this the same animal?
A typical G5RV should work okay on 20 meters with out a tuner. They typically require tuning just like any other antenna.
Should that twin-lead/ladder-line/whatever hang straight down? Yes, it should, and not be near other things. That parallel feed line portion is the impedance matching device for that antenna and has to be treated as such (as in tuned). It should be mounted high enough where the coax is the only part of the feed line near the ground.
Just how bad is the SWR?
I think the "super loop" in made by radioworks.
thanks for the site info
YIKES!!!! i just checked their site..............$175.......... i don't think so:D
i've got a 100 feet of new 450 ohm ladder line and a 500 foot spool of insulated wire. a 4:1 balun isn't too costly.
only issue i have is that i would perfer to feed it with ladder line and not coax.
i think i'll keep looking at ladder line fed delta loop plans.
Loops!
How much area do you have to put one up in? That's the biggy. From there it's merely a matter of having enough wire to put up. If you have the option, two or more times the full wave length of whatever the lowest frequency you'll be using is VERY nice to have! That typically means some 'gain' on bands higher than the design frequency/band. It also means one heluva big loop, lots of area required. But in most cases, it's worth it.
The shape of a loop, round, square, rectangular, triangular, some 'other' weird shape isn't all that important, sort of. The more area -inside- that loop the more efficient it will be. That difference in efficiency isn't going to be huge, but there is a difference. A triangular shaped loop is probably the least efficient, but the easiest to get up. That round loop is the most efficient, but the hardest to get up. A rectangular (or close to sort of rectangular) shape is probably the most common. Until that rectangular thingy gets real 'skinny', that loop ought'a work okay. When it get's real 'skinny' you ought to call it a 'folded dipole', sort of, and then things start changing rapidly.
Can you have stuff inside that loop, like a house, trees, and like that? Yes. That stuff does affect things to some extent, but probably not all that 'badly', sort of. (Tear that house down and live in a cardboard box? You gotta put priorities where they belong!)
A typical horizontal full wave loop has an input impedance somewhere around 100 - 150 ohms (give or take a little). Feeding a loop with coax can certainly be done if you use an impedance matching device of some kind (gamma? 75 ohm electrical 1/4 wave section?). That pretty well limits you to one band though. If you can, feed the thing with ladder line through a tuner and use it on any higher bands. You are going to loose some efficiency (power transfer) with any multi-band antenna like that so it's not really a big deal, sort of.
Polarity with horizontal loops depends on where you feed the thing and it's general shape. Square loops are easy to figure for polarity. A corner means vertical polarity, the center of one side means horizontal polarity. When the loop's shape isn't exactly 'regular' that polarity thingy gets more complicated. This is one of those 'generalized' thingys, meaning it just depends on a lot of factors, and is going to be different for each installation because of what's around it. So change the feed point till you find the 'sweet spot' you're looking for.
Ladder line and tuners.
Lots of misinformation about those things. Is there losses when using a tuner? Sure, but not as much as you might think. Is ladder line difficult to 'work' with? I wouldn't say it's more difficult than coax but it's certainly different. Just a different set of "do's" and "don't do's". What's the advantages? Biggest one for me is that it doesn't really matter what that SWR is, it isn't going to hurt/damage the ladder line like it can coax. If that tuner can handle whatever the impedance mismatch is, then who cares! The typical $19.95 tuner isn't gonna work in most cases, so get ready for it. 'Nuther one'a them 'bigger is better' thingys.
And lastly, tuners and ladder line don't do miracles, they have limits. Sometimes those 'limits' can be in unexpected places, not where you'd expect them to be. Most of those limits deal with the harmonic relationships between bands. Or maybe the different portions of bands?
Loops are not the best answer for -every- antenna choice/requirement. They do have some characteristics that are nice, and I've found that they will usually work fine for most of my antenna requirements. I like them! (You couldn't tell that, could you?)
    Tucker442 has left the room.
    LIVE 10:00 AM EST :cool:
  • @ Charles Edwards:
