Steel tube amp
Mar 12, 2011
2
I want to know where i can get a steel tube amp. I would like to be able to find them on web...I want to use a super six elkin to drive it. I'd like to be able to do around 5000 to 10000 watts. I will listen to all suggestions. I will be saving for this project so i need to get a close price. Thanks for all the help.
I am trying to acheive time travel....any pointers? I just want to talk when I want to talk on ch19. Tell me how....
Height is might on HF.
Antenna, antenna, antenna.
A good yagi, high in the air. Then if you still need to add anything else add it after you put that antenna way up in the air 70 feet or higher.
I had to replace an swrpill this weekend, no rhyme or reason I can see for it to go but I may need to check my bias voltage which hasn't been checked since me,bob and danny boy originally built that "box"/amplifier.
It went dead collector to emmiter but showed fine base to collector.
    63Sprint has left the room.
