Kenwood TH-F6A programming software confirmation
Need2Know
KK4GMU - Ocala, FL
Jan 26, 2012
142
12
28
Ocala, FL
www.muccings.blogspot.com
I'm learning the TH-F6a HT programming software for which there is not a lot of instruction.
Can you confirm if I've entered the following data into the window, below, correctly before I enter a dozen more incorrectly:
Station name: K4VRC
RX: 443.225
TX: 448.225
PL: 103.5
Repeater
I've separated groups of stations into three memory groups:
Local area nets is in Group 1 (Channels 1 through 49)
Nearby repeaters in Group 2 (Channels 50 through 99; I need to move this first "repeater" entry to Channel 50)
Public Safety channels in Group 3 (Channel 100 trhough 149)
Any more programming "words of wisdom?"
I just picked up this radio today. I haven't had the opportunity yet to research the programming software. Does anyone know if there is a Linux compatible version, or if the Windows version will run with Wine?
Sent from a mobile device via Tapatalk
Station name: K4VRC
RX: 443.225
TX: 448.225
PL: 103.5
Repeater
Looks good to me (y)
I don't use Linux much, hardly ever. However, I would think the Windows version would work with wine?
programming
I dont see a + or - on your offset but it looks correct. I wouldn't worry much It is easy to correct if you don't make the repeater.
Well, it looks like I'm making a shift to the RT Systems USB cable and programming software. I guess I'm rather fickle when it comes to technology I'm not comfortable with. The serial/USB converter I ordered would probably be touch and go - it might work - it might not - so I am told. So I'm returning $100 worth of Kenwood serial programming cables back to GigiParts and getting $99 worth of RT Systems USB cables and programming software for my 2 Kenwood radios.
The hour's worth of data entry into the 6A programming software won't go to waste. It was a good learning experience. I doubt that I will be able to simply copy and paste the Kenwood channel data into the RT Systems' spreadsheet format. But at least I know that when one radio's programming is complete, I can just port it over to the other radio via the RT System software. Not sure it is that simple using the Kenwood software for 2 different models of radios designed 10 years apart.
I like the RT software I got it for my icom 92ad and it was pretty simple to use I got it for my kenwood th72ad it was cool just downloaded it from their website and used the USB cable supplied by kenwood. no need for extra cables to buy.
    63Sprint has left the room.
