Converting a Cushcraft AR-10 into an AR-11
ahh
Feb 29, 2012
18
6
13
--Hi, all. I am selling one of my CB/10 meter antennas and will be left with a Cushcraft AR-10. What exactly should be done to "convert" the AR-10 into an AR-11? (the AR-11 is a CB antenna that is no longer made...for you guys that have no idea what an AR-11 is). I like experimenting, so what I think I will do is just add a piece of tubing inside of the smallest. I think the smallest piece of aluminum tubing is 1/2 inch, so maybe I will just add a 7/16 inside of it, and adjust accordingly. I know there is a coax stub near the bottom of the antenna, but hopefully just adding the extra bit of tubing will be enough for use in the CB range and I won't have to mess with the coax stub. Any suggestions?
http://www.cushcraftamateur.com/pdffiles/AR-10.pdf
it's speced for up to 200 inches above the insulator/ring . i'd add 16 inches for the chicken band . you may (or may not) have enough extra over lap in the sections to get that or close to it . the manual shows the four top sections to be 4 ft long . with a 4 inch overlap they will go to 15 ft. . it doesn't list the length for the base assembly . but it is 3 ft 4 inches of vertical above the insulator you should be golden . i wouldn't be terribly concerned if it's a few inches short . and it looks like youre right about the top piece being 1/2 inch diameter , but 7/16 will be too big to fit in it . 3/8 is what you want .
Shop Steelworks Aluminum Round 3/8 x 3' at Lowes.com
I spent 4 hours Monday turning a old 11m big stick into a 10m stick, so i dont need a tuner for 10m. Why in the world would you go from high class to zero class?
--Thanks for the reply. Tomorrow I plan to buy some 3/8 tubing and add it to the antenna so I can work my CB radio friends. Hopefully, after I put the extra tubing in, it will be within the frequency range I want, and I won't have to make several trips on the roof to get the antenna adjusted, lol.
YES !!! YES !!! YES !!!
CB'ers have more freedom of speech than hams !!!!
Wrong !
Listen to 147.435 VHF or 14.313 HF.
When im in my druggie episodes ill join in on .435.... freedom of speech oh yea ! If u listen to 38lsb its a bunch of idiots with echo and sounds effects, I wouldn't call that freedom of speech.
Got a hose clamp and a piece of stiff wire maybe a couple of feet long? It'd be cheaper than tubing with no significant electrical differences. A metal coat hanger works just dandy.
Reactions: k5jpd
be sure to let us know how it works for ya .
pics are always appreciated too ;)
    63Sprint has left the room.
