Using YSK-857 Head Separation Kit with FT-897D
MSFRider
Mar 10, 2012
3
Prescott Valley AZ
Hello All,
I'm a soon to be Tech (taking the VEC test on the 31st) and I've purchased a Yaesu FT-897D with the primary interest of using 10 meter phone ad exploring 2 meters. Much of the use will be mobile. To that end I purchased the separation kit YSK-857 listed by Yaesu as the accessory to separate the face of the radio for mounting on the dash and the radio elsewhere. I've read the docs and submitted a request for info to Yaesu but thought I might seek advice from some folks that may have experience in the matter. I appreciate any advice. Thanks!
Bill
Prescott Valley AZ
That is what I'm finding since I received my purchases. I relied on the Yaesu description of accessories and apparently should not have done so. :oops:
The radio is just what I wanted, except for being able to remotely mount it in my vehicle. I likely will keep it for use as a base station and get another radio for my vehicle, one that does have the remote mounting option. Such are the trials of the un-initiated.
Thanks for the input Rich!
There is obviously a misunderstanding either in what you read or between you and Yaesu. I have never seen the YSK-857 listed as an accessory for the FT-897 and if you asked Yaesu about then they probably assumed you made a typo and meant the FT-857 which is what the YSK-857 was meant for. There is no removable faceplate on the FT-897.
I stand corrected. It is right here on the Yaesu page.
http://www.yaesu.com/indexVS.cfm?cm...D=0372FA803B7BBADBF3076C94ACA7A8C5&DivisionID
The problem is that the FT-857 and the FT-897 are identical radios in different boxes. I mean they are EXACTLY the same radio and as such the accessories are the same. The difference is that the FT-857 is meant as a mobile unit and the FT-897 is meant as a base with builtin power supply or as a portable unit with internal battery pack.
At least it sounds like you'll soon have 2 radios. no harm there.
Two radios? Where? The OP bought the FT-897 and a separation kit for an FT-857.
BTW a note to the OP: You will not find that the FT-897 is very suited for use mobile. It does not come with a mounting bracket, in fact there is no mobile bracket for it IIRC, and it is a bit large for mobile anyway. The FT-857 is what you should have bought IMHO based on what you have stated you intend to use it for.
He's keeping the 897 for a base and buying another radio for his mobile.
Thus, 2 radios for the WIN.
The MMB80 Mounting Bracket, It is very nice I have one for My 897.
The Yaesu MMB-80 Mounting Bracket is designed expressly for the FT-897. It will also accomodate the FC-30, if used.
I have used mine mobile lots of times in my Pick-up.
Hey Captain, even the FT 101 had a mounting Bracket
Such is the life of living in an area that the closest HAM store is over a 100 miles away. Have to depend on catalogs and such for info until you can find another source.
Yep, Made a mistake but thee is a silver lining there. As M42Duster stated, keeping the 897 to use on the bench and something different for the vehicle. The wife is even good with that!
I received a reply from Yaesu with the info that the face would not come off to be mounted elsewhere. Now I'll be looking for another radio that fits the bill. I guess I'll just have to brave the traffic and people in Phoenix to visit the Ham Radio Outlet there.
Thanks for the input fellas!
Bill
    Tucker442 has left the room.
    LIVE 10:00 AM EST :cool:
  • @ Charles Edwards:
