Best C.B antenna for under $150?
T23
645
12
28
The best base C.B antenna, and not the fiberglass ones.
I was thinking about an antenna with some gain....
I already have an end fed dipole.
Home brew a 3 Element Yagi or a 2 element Delta loop or Quad.
Both have about the same gain, and are light weight and easy to turn with a small rotor.
if you already have a omni a small beam would be much more effective than a more expensive/bigger antenna .
for a very tight budget the workman 58 for less than $80 shipped is a decent antenna .
W-58 Omni-Directional Antenna - Palco Electronics
and the Hy-Gain SPT-500 Super Penetrator for $170ish shipped should be stronger physically .
Hy-Gain SPT-500 Super Penetrator HF Vertical Antennas - DXEngineering.com
don't know if i would trust a vector 4000 in the storms/hurricanes we get here sometimes . if i had more confidence in it's physical strength it would be my first choice .
    Tucker442 has left the room.
    LIVE 10:00 AM EST :cool:
  • @ Charles Edwards:
