Uniden PC68LTW
It better NOT transmit on the weather channels; that would make it illegal!
If it isn't transmitting on CB; the final transistor may have failed and will need replacement. This is usually caused if/when the antenna's SWR was not adjusted properly when installed. Newbee radio operators usually have this problem quite often. First radio?
Transmits, receives on weather but not on cb,.. any ideas???
I think they were saying that the radio "Transmits on CB, and that it also receives the WX just fine, but that it is not receiving when it is in the AM CB mode".
If this is the case, then that sounds like a pretty funky problem. If the radio is new I would just return it.
Robb,.. Greatvalve1 is correct, it transmits in cb mode but does not receive in cb mode, but receives weather in weather mode,...
It's not my radio it's a friends, I have some knowledge of cbs, although not to the degree most of you, (mostly learned by reading and some good people on here who have helped me),..
I did not realize the final could cause the receive issue since i had key up and tx, on the other hand the owner is a 'cover driver' and uses different trucks, he may have had one with a high swr and taken the final out,.. i'll look into that.
Thank you for your replies....
Greatvalue1, was told,.. my friend was running with another driver, talking away then nothing,.. called the other driver's cell phone and was informed he was answering him but my friend could not hear it. I hooked it up to a SWR/power meter saw it had dead key and swing never actually did a audio check myself. Hope that makes sense,...
Thank you!!
This is a funky issue. Unless he just has a switch in the wrong position it willprobably require someone to track down a bad component in the receive section. The radio probably has a seperate receive board/audio amp for the WX band which may be why it receives and CB doesn't. I bet it's a bad transistor somewhere in the audio chain.
This issue needs a professional to find the problem.
If I had to guess though, I would say first look internally at the WX/CB switch to see if there are any unsoldered connections.
If the connections on the switch look fine then I would agree with RatsoW8.
Thank you for everyone's responses,.. It's basically getting past my present scope of knowledge, that's what I needed to know to let my friend decide if he wants to spend the money repairing it or buy a new one!
    Tucker442 has left the room.
    LIVE 10:00 AM EST :cool:
  • @ Charles Edwards:
