Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > HF Bands and HF Rigs
Amateur Callsign Lookup
Enter Callsign:
Flex 5000 and ESSB
Like Tree2Likes
Reply
  #1
Old 01-16-2012, 05:22 AM
W1MSG's Avatar
Now W1MSG
W1MSG is on a distinguished road
Default Flex 5000 and ESSB
Flex 5000 and Smooth Audio with Rack Gear
I just upgraded from a Flex SDR-1000 to the Flex 5000A and it was probably the best upgrade I have ever done. The abundance of new options on the 5000 over the 1000 is amazing.
I am somewhat of an audiophile and have a complete audio rack system that was set up for the SDR-1000, I thought it would be pretty much plug and play, well I was mistaken. The 5000 is a bit pickier on whats coming into the radio. I plugged in to the back of the 5000 and left all of the PSDR settings at factory default with all the processing turned off, that was my first mistake. I had horrible pumping and scratchiness on the audio. I then found a wonderful set up article by W1AEX, Rob Connelly. Rob explains in detail how to set up the PSDR gain settings. His recommendations worked to an extent but I still had a bit of scratch, so this is how I managed to get my audio straightened out.
I did a bit of searching on the Flex knowledge base and found that the TX Buffers for phone on the DSP tab needed to be set for 4096 so I made that change. Then I had to get the mic gain on the main view of PSDR to work correctly set at 35, which is ½ scale. I opened the mixer with the mic gain set at 35 and set the meter to MIC and tried to get the meter reading right around 0. I had to enable the mic boost to keep the mixer setting at the ½ way point or just a touch less. If you use more than that you tend to pick up that nasty scratch in the audio. I don’t use the leveler and the ALC settings are at the default menu settings. My ALC was between -5 and 0 on the meter. My audio is now clean and smooth just as it had been on my SDR-1000. Audio reports were excellent and I am now a happy audiophile with a Flex 5000.
My Rack gear consists of the following;
AKG Preception 220 Condenser Michrophone with POP Filter
Behringer UltraGain PRO Mic-2200
Behringer Ultra Curve PRO DEQ-2496 Parametric EQ
Behringer UltraFex PRO EX3200 Ultraband sound enhancer
Behringer Virtualizer PRO DSP2024P Effect processor
This set up works the best for my voice characteristics and what really sounds good to me, your experiences may vary.
__________________
Craig, W1MSG
TS-2000 / G5400B / Gulf Alpha 2mCP, M2 70cmCP Beams
Flex 5000 w Audio Rack / Palstar AT2KD / Commander HF-2500 Amp / AKG Perception 220 Mic
Wouxun Dual Band HT
  #2
Old 01-16-2012, 03:59 PM
Moleculo has disabled reputation
Default
Nice write-up. Can you do any recordings of it so we can hear what it sounds like?
  #3
Old 01-16-2012, 04:08 PM
W1MSG's Avatar
Now W1MSG
Default
Quote:
Yes I can, The flex built in recorder will record the processed audio but the files are kind of large. I'll have to find a program to make them smaller without sacrificing the quality. Any suggestions ?? The flex saves them as wav files.
__________________
Craig, W1MSG
Wouxun Dual Band HT
  #4
Old 01-16-2012, 04:46 PM
W1MSG's Avatar
Now W1MSG
Default
I converted a test audio clip to mp3, there isn't much degradation in the audio with the conversion but there is a non registered logo that's a bit annoying.
Let me know what ya think. I don't have the best voice for radio but then again I'm not a broadcaster. Its natural and sounds just like me
__________________
Craig, W1MSG
Wouxun Dual Band HT
  #5
Old 01-17-2012, 10:53 AM
Klondike Mike's Avatar
Senior Member
Klondike Mike is on a distinguished road
Default
Well, if it sounds like that on my receive end, that would be superb!
__________________
9WR2000
  #6
Old 01-17-2012, 11:03 AM
W1MSG's Avatar
Now W1MSG
Default
Quote:
It should sound pretty close Mike, I had a couple of people do some recordings and play them back over the air and it pretty much sounds just like that.
I also did a little work on my article and put it in PDF format with some graphics. Not alot of folks bother with rack gear on a flex, buy hey ya gotta have some kind of knobs to play with..
__________________
Craig, W1MSG
Wouxun Dual Band HT
  #7
Old 01-17-2012, 11:47 AM
Senior Member
Default
What kind of control do you have for TX bandwidth? What setting where you running with that sample?
__________________
9WR2000
  #8
Old 01-17-2012, 12:34 PM
W1MSG's Avatar
Now W1MSG
Default
The recording was done at a 5k wide transmit profile. The Flex 1000 and 5000 are capable of up to 10k wide on SSB 20k on Double SSB, AM, and FM. Its very flexible when it comes to TX profiles. The 1500 and 3000 are restricted to narrower profiles but I dont know exactly what the limits are. Here is a picture of my TX Profile setup.
__________________
Craig, W1MSG
Wouxun Dual Band HT
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
