Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > HF Bands and HF Rigs
Amateur Callsign Lookup
Enter Callsign:
FT101E Lazy S Meter
Like Tree1Likes
Reply
  #1
Old 02-23-2012, 10:53 PM
Junior Member
siltronix_man is on a distinguished road
Default FT101E Lazy S Meter
Looking for some help,seems one of my 101e has a lazy meter meaning meter will not move unless a real strong signal comes in ive tried the static buildup thing with a dryer sheet that did not work s Meter adjustment also did not work anyone else got any ideas thanks
  #2
Old 02-24-2012, 04:07 AM
Senior Member
kc8adu is on a distinguished road
Default
fuse lamp?
is it deaf too?
they dont get much recieve if the lamp goes.
hookedon6 likes this.
  #3
Old 02-24-2012, 04:24 AM
Junior Member
Default
maybe ill try the fuse lamp the signals are decent but like the static floor is always real quiet
  #4
Old 02-24-2012, 05:35 AM
Junior Member
Default
Well checked it out swapped with another ft101e lamp i know that works same result
  #5
Old 02-24-2012, 07:15 AM
Beetle's Avatar
Senior Member
Beetle is on a distinguished road
Default
RF gain turned all the way up? Maybe replacing the tube used as the meter driver.
__________________
If you're like everybody else,
you're about average.
73 de K7KBN
CWO4 USNR RET.
  #6
Old 02-24-2012, 07:20 AM
Junior Member
Default
yab rf is all the way up you mean replacing the driver tube?
  #7
Old 02-24-2012, 09:15 AM
hookedon6's Avatar
hookedon6 is on a distinguished road
Default
is it inop on all bands or just one band?
cycle the band switch. they sometimes need the contacts cleaned
  #8
Old 02-24-2012, 09:50 PM
Beetle's Avatar
Senior Member
Default
Quote:
No, the METER driver - the tube that operates the AGC, which is what the S meter operates from. You'll probably need the manual or a schematic.
__________________
73 de K7KBN
CWO4 USNR RET.
Reply
Bookmarks
Worldwide Radio Forum
« ICOM 718 | ts-440s »
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Tokyo Hy-power, HL-1.5KFX: Replacing bad incandescent meter bulb with LEDs AudioShockwav Amateur Radio Modifications 2 06-01-2012 11:33 AM
Need Help Setting Up Radio Neuro CB Band and CB Radios 24 06-10-2009 01:30 PM
Watch those meter leads! Captain Kilowatt General Ham Radio Discussion 21 10-20-2008 06:25 AM
Mirage 88 RX/TX Meter Adjustment JJim General CB Services Discussion 3 02-03-2007 11:59 AM
Looking for 10 Meter Mod. for YEASU FL 2100 F (80/15 meter) jc4950 Amplifiers 0 07-17-2005 07:25 PM
Powered by vBulletin®
