Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > HF Bands and HF Rigs
Amateur Callsign Lookup
Enter Callsign:
Help me find C13 on FT-101EE
Reply
  #1
Old 02-29-2012, 01:31 PM
443 443 is offline
443 is on a distinguished road
Default Help me find C13 on FT-101EE
Ok, I got this old Yaesu, and it was working good, had a problem when switched to 160 meter blows fuse, found C131, replaced it with 1000pf silver dipped mica cap...
Below it is a burned up capacitor, I mean burned up bad. I have seen notes to replace C13 (80pf 1000V) cap, as it could go bad, and wondering if it looks like a big ass electrolytic or not because the only capacitor I see in the area that various web pages have said to find C13 is C131 which is the cap to fix the 160M fuse blowing problem...
Anyway, I just need to locate this damn C13 cap in here and change it out, for some reason I have not been able to find any 80pf cap in this area, only a burned up beyond recognition electrolytic cap that I cannot figure out what it is/was for or any idea what value, see pic, please help! Thanks in advance 73.
  #2
Old 02-29-2012, 01:56 PM
443 443 is offline
Default
Ok, I found C13, it was under the "lip" on the edge of the chassis up against the chassis wall and had a piece of clear vinyl hose or something around so I wasn't sure what it was. It has a Yaesu part number on it, checked it with my cap meter, shows good, around 85pf.
So now I need to figure out what that burned up electrolytic capacitor is/was.... looking at schematics, it's attached to ground (chassis gnd) on one side and the other is connected to 2 large resistors, mounted to a standoff strip, has a wire going back to one of the pins of the driver tube.
  #3
Old 02-29-2012, 02:17 PM
AudioShockwav's Avatar
Extraterrestrial Admin
AudioShockwav has disabled reputation
Default
Look on the Schematic for C-109, 2.2uf@450 volts on the main chassis... i think
I do not have a sch here, and the only chassis I have left is 60 miles away....
__________________
Radio-active
NASA/SOHO
there is no dark side in the moon, really. As a matter of fact it's all dark
  #4
Old 02-29-2012, 02:34 PM
443 443 is offline
Default
I am having trouble finding a full blown schematic of the PA area of the chassis, only the little part around the final output tubes...
This capacitor comes off Pin 8 of the Driver tube and goes to Chassis Gnd.
Looking for C109 on the schematics, but to no luck yet thanks.
  #5
Old 02-29-2012, 02:38 PM
Default
OK, found a Sch online, go here
http://hamradio.online.ru/ftp2/man_sch_ft101.pdf
Download it.
Go down towards the bottom, shows 12by7a driver, follow the line off pin 8.
__________________
Radio-active
NASA/SOHO
  #6
Old 02-29-2012, 02:43 PM
Default
couple of resistors, a choke, and then look for C109...see the +/_ next to the electrolytic cap...to the right and slightly below the 12by7a.
You can get a complete replacement set of caps here.Yaesu FT-101E HF Transceiver Capacitor Replacement Kit | eBay
Not bad for $35 bucks.......
__________________
Radio-active
NASA/SOHO
  #7
Old 02-29-2012, 06:06 PM
443 443 is offline
Default
Thanks for the info Jeff, but this capacitor only goes from Pin 8 then to ground, the C109 in that schematic shows it passing through 2 resistors and a choke or something before it connects back to pin 8, so either the schematic is wrong and the part is right, or C109 isn't the right cap (though from it's large size and obviously Electrolytic composition you would think it must be). Wish someone had a radio to look inside of and confirm for me. I will keep looking for some other schematics. I think the one you posted the link to is for the oldest FT-101, (no suffix), so it may indeed have been a different schematic than my radio (the EE model, should be same as E/EE/EEX)
  #8
Old 02-29-2012, 06:39 PM
Default
If I get down in the Valley this weekend, I will look, I have a E chassis in storage....just have to get down there to look at it.
The only cap I see that comes off of pin 8 to ground directly is C-8, 4700 Pf.
__________________
Radio-active
NASA/SOHO
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
where to find an assortment of high voltage electroloyic caps for cheap? towerdog Home Brew 9 12-02-2012 09:38 AM
cant find my call sign Chatter General Ham Radio Discussion 9 11-18-2009 02:39 PM
Where to find a 1.2ghz / 440mhz duplexer or... Moleculo Tuners, Mics, Meters & other Accessories 3 07-20-2009 03:26 PM
Where may one find a good President Lincoln? Red Ranger CB Band and CB Radios 6 09-23-2008 10:18 AM
So, where do I find a W5LZ CB Antennas 1 08-09-2005 01:31 PM
Powered by vBulletin®
