03-19-2012, 07:06 PM
 | W9WDX Amateur Radio Club Member | | Join Date: Jun 2010 Location: Ca
Quote:
Originally Posted by Moleculo You might have also introduced a ground loop if the PC and radio have different ground locations. Make sure they're using a common ground to avoid this & make sure that the PC and power supply for your rig are using the same 110 circuit. | Both on the same circuit 110vac. Pc is not grounded.
__________________ NSA We're watching you! |
