Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > HF Bands and HF Rigs
Amateur Callsign Lookup
Enter Callsign:
Using YSK-857 Head Separation Kit with FT-897D
Reply
  #1
Old 03-15-2012, 08:42 PM
Junior Member
MSFRider is on a distinguished road
Default Using YSK-857 Head Separation Kit with FT-897D
Hello All,
I'm a soon to be Tech (taking the VEC test on the 31st) and I've purchased a Yaesu FT-897D with the primary interest of using 10 meter phone ad exploring 2 meters. Much of the use will be mobile. To that end I purchased the separation kit YSK-857 listed by Yaesu as the accessory to separate the face of the radio for mounting on the dash and the radio elsewhere. I've read the docs and submitted a request for info to Yaesu but thought I might seek advice from some folks that may have experience in the matter. I appreciate any advice. Thanks!
Bill
Prescott Valley AZ
  #2
Old 03-15-2012, 09:00 PM
wile2u is on a distinguished road
Default
ummm. i don't think the head on the ft-897d detaches. so if you bought the kit for the ft-857d it won't work.
__________________
73, Rich W6ABJ
The influence of each human being on others in this life is a kind of immortality. -JQA
  #3
Old 03-16-2012, 09:36 AM
Junior Member
Default
That is what I'm finding since I received my purchases. I relied on the Yaesu description of accessories and apparently should not have done so.
The radio is just what I wanted, except for being able to remotely mount it in my vehicle. I likely will keep it for use as a base station and get another radio for my vehicle, one that does have the remote mounting option. Such are the trials of the un-initiated.
Thanks for the input Rich!
  #4
Old 03-16-2012, 06:05 PM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt is on a distinguished road
Default
There is obviously a misunderstanding either in what you read or between you and Yaesu. I have never seen the YSK-857 listed as an accessory for the FT-897 and if you asked Yaesu about then they probably assumed you made a typo and meant the FT-857 which is what the YSK-857 was meant for. There is no removable faceplate on the FT-897.
I stand corrected. It is right here on the Yaesu page.
http://www.yaesu.com/indexVS.cfm?cmd...8C5&DivisionID
The problem is that the FT-857 and the FT-897 are identical radios in different boxes. I mean they are EXACTLY the same radio and as such the accessories are the same. The difference is that the FT-857 is meant as a mobile unit and the FT-897 is meant as a base with builtin power supply or as a portable unit with internal battery pack.
__________________
  #5
Old 03-16-2012, 07:10 PM
m42duster's Avatar
Senior Member
m42duster is on a distinguished road
Default
At least it sounds like you'll soon have 2 radios. no harm there.
__________________
"No bastard ever won a war by dying for his country.
He won it by making the other poor dumb bastard die for his country."
~General George Patton, Jr.
  #6
Old 03-16-2012, 07:40 PM
Default
Quote:
Two radios? Where? The OP bought the FT-897 and a separation kit for an FT-857.
BTW a note to the OP: You will not find that the FT-897 is very suited for use mobile. It does not come with a mounting bracket, in fact there is no mobile bracket for it IIRC, and it is a bit large for mobile anyway. The FT-857 is what you should have bought IMHO based on what you have stated you intend to use it for.
__________________
  #7
Old 03-16-2012, 07:44 PM
m42duster's Avatar
Senior Member
Default
He's keeping the 897 for a base and buying another radio for his mobile.
Thus, 2 radios for the WIN.
__________________
  #8
Old 03-16-2012, 07:49 PM
AudioShockwav's Avatar
Extraterrestrial Admin
AudioShockwav has disabled reputation
Default
The MMB80 Mounting Bracket, It is very nice I have one for My 897.
Quote:
The Yaesu MMB-80 Mounting Bracket is designed expressly for the FT-897. It will also accomodate the FC-30, if used.
I have used mine mobile lots of times in my Pick-up.
Hey Captain, even the FT 101 had a mounting Bracket
__________________
Radio-active
NASA/SOHO
there is no dark side in the moon, really. As a matter of fact it's all dark
Reply
Bookmarks
Tags
ft-897d, ysk857
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenwood Tranciever TK-630H, Mics, Dual Control Head Kit & 2 Heads, Cables Ebay Amateur Gear eBay Auctions Ending Soon 0 02-11-2012 12:40 AM
Yaesu FT-8800R 50W 2m 70cm Transceiver plus YSK-8900 Separation Kit with Cables Ebay Amateur Gear eBay Auctions Ending Soon 0 02-04-2012 10:50 PM
Yaesu YSK-8900 Separation Kit Ebay Amateur Gear eBay Auctions Ending Soon 0 01-07-2012 02:50 AM
TEXAS STAR 1600 WITH FAN KIT AND REMOTE HEAD TonyV225 Amateur Radio Gear Swapshop 4 02-01-2010 10:21 PM
Powered by vBulletin®
