Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > HF Bands and HF Rigs
Amateur Callsign Lookup
Enter Callsign:
Yaesu 101E Receive Problem
Like Tree1Likes
  • 1 Post By Shockwave
Reply
  #1
Old 07-01-2012, 06:16 PM
Rudes is on a distinguished road
Default Yaesu 101E Receive Problem
My radio was working fine up until recently. My transmit is fine but the audio on my receive is very low and the meter does not move at all in the receive mode. We've had some lightning storms recently. Don't know if that could have damaged the radio? I hooked another radio up to the antenna and it is fine. Anyone know where I should look for the problem? Come to think of it...isn't there an IC thats used for the audio? Could it be that?
  #2
Old 07-01-2012, 06:45 PM
AudioShockwav's Avatar
Extraterrestrial Admin
AudioShockwav has disabled reputation
Default
First thing to do is check the bulb that is located on the rear panel of the radio.
That bulb is used as a fuse in case of severe overload from a very strong signal.
__________________
Radio-active
NASA/SOHO
When I was a child
I caught a fleeting glimpse
Out of the corner of my eye.
I turned to look but it was gone
I cannot put my finger on it now
The child is grown,
The dream is gone.
but I have become comfortably numb.
  #3
Old 07-01-2012, 07:04 PM
KC9Q's Avatar
Contributing Site Sponsor
KC9Q is on a distinguished road
Default
Another place to look is the big multi-gang relay (RL-1) located on the top side of the radio. The contacts are known to get dirty after a while and need to be burnished clean with a relay file, or some paper bag with contact cleaner on it. That relay is the cause of 90% of the radio problems. Another item may be an electrolytic cap in the receiver section. The radio is over 30 years old.
Maybe we should get together. Mine receives but has no TX audio. Hi, Hi.
  #4
Old 07-02-2012, 05:27 PM
Default
Thanks for the replies guys. Bulb is good and last year I gave the radio the once over and replaced the old caps and cleaned the relay. I'll check the relay again and check the audio board.
  #5
Old 07-02-2012, 09:10 PM
Senior Member
Shockwave will become famous soon enough
Default
If the bulb is good and this was a result of an electrical storm, 99% chance you have lost the first RF amp in the receiver. As I recall this radio uses a MOSFET front end, perhaps a 3SK40 or 3SK45. Very susceptible to static discharge and a common failure in these circumstances. In any event the transistor you are looking for has 4 wires and plugs into a green socket on one of the smallest plug in boards on top of the radio. No soldering required as the part plugs in for easy replacement. The bad news is this part is out of production but still available from some suppliers like RF parts. Many other transistors work well here too. Yeasu switched over to the 3SK51 in the later 101ZD series. I even remember stealing the mixer transistor out of an old Cobra 148GTL back in the day to get my 101E back up after a storm.
mr bigo likes this.
  #6
Old 07-05-2012, 10:06 AM
Default Transistor
Hey Shockwave...thanks so much! That transistor was the culprit. I guess even with the antenna and radio both grounded things like this still happen. I will be sure to disconnect my antenna whenever possible during thunder storms.
  #7
Old 07-05-2012, 04:25 PM
Senior Member
Default
Glad to be able to help Rudes. That what the forum is about.
  #8
Old 07-31-2012, 10:07 PM
Junior Member
radio475 is on a distinguished road
Default
Take off the top and look for a small vertical curcit board just to the right of the large metal box to the middle front of the radio. Unplug this board. Replace the four leged fet. I think it's 2SK30. It's the only one that has a socket and is easily removed. Becareful to replace the four legs of the new fet, just as the old one came out. Good Luck.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Galaxy Saturn Turbo SSB receive problem Warlock35po General CB Services Discussion 2 02-25-2010 06:02 AM
HR2600 Fix For Receive Display Problem Sonwatcher HF Bands and HF Rigs 2 01-31-2010 05:33 PM
Yaesu 101e Drifter HF Bands and HF Rigs 4 07-23-2009 11:04 AM
Yaesu VX-8R - with audio problem Akytarus HandiTalkies 6 07-21-2009 09:14 PM
COBRA 29 GTL RECEIVE PROBLEM ???? Switch Kit General CB Services Discussion 6 05-09-2007 06:35 AM
Powered by vBulletin®
