Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > HF Bands and HF Rigs
Amateur Callsign Lookup
Enter Callsign:
Eduk8tr...you're Icom 706mkiig mount is brilliant
Reply
  #1
Old 07-12-2008, 10:45 AM
Moleculo has disabled reputation
Default Eduk8tr...you're Icom 706mkiig mount is brilliant
I saw your cigarette lighter mount you did for your 706 in your picture album. That is brilliant! Did you come up with that idea on your own or did you steal it? Does it move around or work it's way out of there on a bumby road?
http://www.worldwidedx.com/members/e...g-install.html
  #2
Old 07-12-2008, 12:45 PM
IMD262's Avatar
Senior Member
IMD262 is on a distinguished road
Default
I Think I'll steal the idea, cheap,simple and no hassle.
  #3
Old 07-12-2008, 02:47 PM
EDUK8TR's Avatar
EDUK8TR is on a distinguished road
Default
Quote:
Originally Posted by moleculo View Post
I saw your cigarette lighter mount you did for your 706 in your picture album. That is brilliant! Did you come up with that idea on your own or did you steal it?Does it move around or work it's way out of there on a bumby road?
Nope, didn't steal it. I kept looking at that blank that had the cigarette lighter and really considered pulling the center console out and removing the blank and installing something in its place. Simplicity sparked the use of the old cell phone charger. That charger had some good spring loaded side friction pads on it. No, it doesn't work its way out on bumpy roads.
Wayne C.
__________________
"To be is to do"-Socrates;
"To do is to be"-Sartre;
"Do Be Do Be Do"-Sinatra;
WV4L,CDX-787,AK2787
Mobile/Base
Icom706MkIIG/Kenwood TS-2000 w/LDG AT-1000
Stock mic or W2ENY headset on VOX/D104 w/Heil HC-5 or W2ENY headset on VOX
High Sierra 1800Pro w/N2VZ Turbo Tuner,Larson NMO 2/70B/TX-472 tower w/ 80M Horizontal Delta Loop, 20-6M K4KIO Hex beam, Gulf Alpha Dual Band Cross Polarity 7X7El. 2M:10 El.v70 CM beam, Arrow 146-440GP
Ameritron AL80A
  #4
Old 07-13-2008, 08:37 PM
Happy_Hamer's Avatar
Forum Administrator
Happy_Hamer has disabled reputation
Default
Quote:
Wayne C.
Wayne,
Do you have larger pictures? put a post in the admin section and I will make a pdf of your setup, nice idea you have there
__________________
That's how I roll!!
  #5
Old 07-16-2008, 06:11 PM
74IN's Avatar
Senior Member
74IN is on a distinguished road
Default
Do you go there for a good laugh sometimes HH?
__________________
  #6
Old 07-16-2008, 06:21 PM
74IN's Avatar
Senior Member
Default
I'm lazy, double faced tape squares are handy.
__________________
  #7
Old 07-16-2008, 07:08 PM
EDUK8TR's Avatar
Wink
74IN,
Looks good! I thought about doing the same thing when I was looking over what I wanted to do. I also wanted to be able to remove the head to store it else where from prying eyes who might zero in on my PU with the large antenna. That at any rate is part of the plan.
Wayne C.
__________________
WV4L,CDX-787,AK2787
Mobile/Base
Ameritron AL80A
  #8
Old 07-16-2008, 07:27 PM
74IN's Avatar
Senior Member
Default
I can still pop it loose the regular way, not as easy as yours.
One good thing is, the shifter hides it in park.
__________________
Reply
Bookmarks
Tags
706 mount, amateur radio, good ass mount, ham radio, icom, icom 706, install
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
