Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > HF Bands and HF Rigs
Amateur Callsign Lookup
Enter Callsign:
Help with FT-857D
Reply
  #1
Old 07-21-2009, 04:26 PM
Junior Member
N2JBO is on a distinguished road
Default Help with FT-857D
How do I get the radio to go above 33 MHz ?
I have all my HF frequencies programmed in, but I turn the Select knob and it goes from 0.000 - 33.000 and then back to 0.000
This has me baffled.
Thanks in advance, Dave
Worldwide Radio Forum
  #2
Old 07-21-2009, 04:41 PM
Junior Member
jjk9 is on a distinguished road
Default
Try the "Band" switches/buttons to reach different bands...
  #3
Old 07-21-2009, 04:55 PM
Senior Member
moleculo has disabled reputation
Default
The Band down/up buttons are right above the big knob on the right.
  #4
Old 07-21-2009, 06:40 PM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt is on a distinguished road
Default
Quote:
Quote:
Agree with above. Basically you have to select the 6m band and tune 30-55 MHz from there.
__________________
Light travels faster than the speed of sound, this is why some people tend to appear bright, until they decide to speak.
  #5
Old 07-21-2009, 09:40 PM
TonyV225's Avatar
Senior Member
TonyV225 is on a distinguished road
Default
Thats it the band select buttons takes care of it but as said you will have to spin the vfo a bit aswell
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #6
Old 07-22-2009, 03:41 AM
Junior Member
Default
Thank you all for the replies.
I was just tired and could not see straight, I found the correct buttons.
All is well. I am thoroughly enjoying my NEW RIG.
73 de Dave - N2JBO "Just Being Obnoxious"
  #7
Old 07-22-2009, 09:21 AM
Senior Member
Default
The 857d is a good rig, but navigating through all the features with so few buttons can be a little confusing. I still sometimes have that problem with my 897d (it's big brother) if I haven't used it for a while.
  #8
Old 08-22-2009, 11:04 AM
Junior Member
Unhappy My FT-857D won't power up
I was using the rig just a little while ago. I had it powered up and tried to UNLOCK the head and reposition the mike cable to the bottom instead of the
side of the radio. The radio just shut down. I checked the 2 fuses on the power cord, okay, the LDG Z-100 tuner and the LDG FT-Meter still work.
But the radio will not power up ?
Help, thanks in advance,
Dave
  #9
Old 08-22-2009, 02:05 PM
Happy_Hamer's Avatar
Forum Administrator
Happy_Hamer is on a distinguished road
Default
I would check the brass tabs behind the face of the 857, sounds like one may have got bent?
Let us know
__________________
That's how I roll!!
  #10
Old 08-22-2009, 02:16 PM
Junior Member
Default
Quote:
Let us know
I do not see any "Brass Tabs" behind the faceplate,
only the connector for the short connection cable ???
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
