Question About Using AM mode on HF  | |
07-29-2009, 01:45 PM
|  | Senior Member | | Join Date: Jul 2008
| | While the following post may seem somewhat comical, it actually isn't far off...
Quoted from The Five Hurdles - K1JJ Quote:
The Five Hurdles
Tom K1JJ.
I often hear new AMers asking " What do I need to put together an AM station that is considered "advanced" "?
IE, "How can I cut right to the chase and be a strapper right away"? :-)
Just what goals or systems do I need in place to fully appreciate what fidelity AM has to offer for both transmitting and receiving?
How do I test my gear to insure it's doing just that?
And, how can I give out accurate audio reports to help other newcomers?
Here's one ham's opinion as to where to focus your energy to arrive at these goals. This and the next series of articles address these and other important questions.
1) I feel the first thing any AMer (worth his salt)should do is set up a decent, ~8-12kc wide-band receiver. It's MANDATORY to pick off the audio from the detector and drive an external >20watt hi-fi amplifier with big, good speakers....four speakers mounted on the four ceiling /wall corners. Audio sweep the complete RX system from antenna to 8 ohm audio output to be sure it is clean and really goes 20-10,000 hz. Those I.F.'s can fool you sometimes.
So many times I've visted shacks where guys think they have good rx audio with a "stock" or even modified receiver...but are really missing the deep lows and high end - not to mention the inherent distortion generated by most receiver audio sections.
Until one has heard the likes of WA1QIX, K1KW, W2INR, WA1HLR, KG2IR, AA3WH and others in ass kicking loud "FM Radio Quality" surround sound, it's hard to accept what I'm saying. It's truly amazing how good these guys sound when they rumble the room and you can hear their subtle breathing, (panting) sighs and the clean high frequency harmonics of their voices.
The receiver detector into a hi-fi amplifier /big speaker system is the only way to get this sound.
Turn up your high end FM stereo on a mellow radio announcer sometime to see what I'm talking about -these AMers sound even better.
Listening to fine Hi-Fi RX audio reminds you of why you are in this AM game in the first place - and motivates.
2) The next challenge is to get your AM transmitter to audio sweep cleanly (VERY CLEANLY) from say 40hz- 7kc or higher. On the scope. This in itself is a challenge.
Once this is accomplished, THEN add the EQ's, processors, expensive mics, etc. Without this transparent transmitter audio, all this stuff is just fooling yourself with trying to match a peaky transmitter with a mic/system that will try to compensate...along with distortion generated by boosting areas that are lacking, non linearities, etc. Cat chasing it's tail... endless asking for reports on the air.
3) Lastly, one needs a good recording system that comes off the detector of the wide band receiver and can play back through your flat transmitter in a transparent manner. This is the best, most informative audio report/service you can give anyone. Nothing else has to be said once it is played....guys react immediately to what they must do once it is heard. Most will then adjust their EQ/processing to satisfy themselves, not the infinite amount of opinions of others who have their own agendas as to what kind of audio THEY prefer or what YOU should sound like.
IE, ask Irb how you sound, then ask Nick...two totally different opinions...and everyone else is gonna say differently too! :-) A clean tape playback is the best way to dial things in to suit your own taste!
IE, ask for a tape, not an opinion when adjusting your rig. And remember, you need a hi-fi RX system as described above to really hear what is being played back to you!
4) Dipole at 50' for 75M.
5) At least 250 watts of carrier and a quiet room background. Little or no blower noise.
Tom - K1JJ
07-29-2009, 02:00 PM
|  | Senior Member | | Join Date: Apr 2005 Location: Central PA
| | LOL ! Thanks guys. Using an amp is not economically feasible right now. Maybe my best bet is to try and listen for 10m am stations in the 29.000-29.200 area. |
07-29-2009, 02:12 PM
| | Quote:
Originally Posted by Sonwatcher LOL ! Thanks guys. Using an amp is not economically feasible right now. Maybe my best bet is to try and listen for 10m am stations in the 29.000-29.200 area. |
lol, give it a shot on 75  , though 10 is much more QRP friendly, even a couple watts when the band is open will do nicely, and with some nice openings recently thats a good chance... Is a group on 10 AM that run converted Johnny I, and II, fun little group.. definitely a cheap way to get a foot in the AM door.. And GOD forbid Run the old converted CB gear  Just imagine an old Johnny I (Whiteface) running into a couple sweep tubes in a metal box suspiciously called a "Footwarmer"  In case you haven't gathered I'm a big fan of AM, have been since the 70s  and no matter what those silly sidebanders say ya just can't get Studio quality audio without Iron |
07-29-2009, 02:38 PM
| | I'd love to get into some AM. I looked at some old gear. I see the Swans had some good power on AM. They seemed to be the cheapest. But do they drift like the Siltronix ? |
07-29-2009, 02:45 PM
| | Quote:
Originally Posted by Sonwatcher But do they drift like the Siltronix ? |
Is a joke somewhere about where the Swan-net meets, and the Swan 3drifty, but to answer your question without some divine intervention yes they do drift |
07-29-2009, 02:52 PM
| | Quote:
Originally Posted by MisterFatty Is a joke somewhere about where the Swan-net meets, and the Swan 3drifty, but to answer your question without some divine intervention yes they do drift  | |
07-29-2009, 05:44 PM
|  | Senior Member | | Join Date: May 2007 Location: tustin, ca
| | I think the joke was about what frequency the swan users meet on.
The answer was any frequency, because eventually they'll drift on by.
__________________ "Y'all mind hanging back? You're jamming my frequencies" -- Tangina in Poltergeist |
07-29-2009, 06:34 PM
| | Quote:
Originally Posted by dudmuck I think the joke was about what frequency the swan users meet on.
The answer was any frequency, because eventually they'll drift on by. |
LOL, yea, thats the one |
07-29-2009, 06:37 PM
| | My thoughts about getting a Swan just flew out the window |
07-29-2009, 07:14 PM
|  | Prestigious Member | | Join Date: Feb 2008 Location: too close to mexico
| | Quote:
Originally Posted by Sonwatcher My thoughts about getting a Swan just flew out the window  | Have you considered a Collins? I've heard a couple on AM and they sounded great and my reciever being a fixed crystal I noticed no drift.
__________________ I U 212 |  | | | Thread Tools | | | | Display Modes | Linear Mode |
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -7. The time now is 08:50 PM. |
