Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > HF Bands and HF Rigs
Amateur Callsign Lookup
Enter Callsign:
Question About Using AM mode on HF
Reply
  #41
Old 08-04-2009, 01:14 PM
Senior Member
HiDef is an unknown quantity at this point
Default
Quote:
Originally Posted by W5LZ View Post
HiDef,
Sorry, no. The TS-440 didn't come that way, it was an after market option from 'InRad'.
Doc! You are thinking of a different radio. I've had my hands on many of these radios. Every one works like I said from the factory. No extra boards. I have seen what you are talking about somewhere but not in a TS-440.
Railroading? Too heavy. I have enough heavy stuff. It gets heavier every day.
Worldwide Radio Forum
  #42
Old 10-20-2009, 06:02 PM
mackmobile43's Avatar
Vern,Vern,Vern,Vern,Vern
mackmobile43 is on a distinguished road
Default
Quote:
Originally Posted by MisterFatty View Post
Is a joke somewhere about where the Swan-net meets, and the Swan 3drifty, but to answer your question without some divine intervention yes they do drift
yes along with its cousin the 1011c siltronix
I have the ts-430 kenwood with the optional 6kc AM filter which is much closer to 8kc and it's an awesome AM transceiver.
__________________
  #43
Old 10-20-2009, 08:13 PM
Supporting Member
W5LZ is on a distinguished road
Default
HiDef,
Every one of them that you've had your hands on may do the fast freq change with a fast spin. But what I'm talking about was a very slow frequency change with just a 'normal' turn of the knob. Not a Mhz per rev of the knob, but a 10 Khz change(?), huge 'fine' tune difference. To the best of my knowledge Inrad was the only source for those modules (or actually it was IRC, International Radio and Crystal, at the time, in Florida). That module was the only thing I wish I had kept when my '440 bit the dust. Oh well.
What ever that rate of change was per rev of the knob, the module slowed it down by at least a factor of 10.
  #44
Old 10-20-2009, 11:26 PM
Senior Member
Default
HiDef,
I just tried one. Slowly tuning I got 12 khz per 1 revolution on CW and ssb. AM was 60khz per revolution. If I fling the tuning knob it moves much faster but I cannot tell just how fast per revolution.
  #45
Old 10-21-2009, 09:26 AM
Supporting Member
Default
Now think of the 'fine' tuning if that were slowed down by a factor of 10.
  #46
Old 10-21-2009, 10:21 PM
Senior Member
Shockwave is on a distinguished road
Default
AM on 75 does not include as many boat anchors as it did in the past. Home brew class E, flex radios, and modified rice boxes with an amplifier are gaining popularity now. I use to run a FT-101ZD however it was a little harder to get right then a FT-101E because you have to bypass the width crystal filter in AM to get receive bandwidth. In fact the optional FT-101ZD AM filter is 100% useless in RX without this mod.
I now use a Kenwood TS-940SAT with a modification I designed. The modification is done in two steps. First is removing AM modulation from the IF strip entirely and modulating one of the RF stages. The second deals with Hi-Fi and changing various caps and the feedback loop used on the mic amp IC. The results are amazing once you back the ALC down.
I've done this type of modification to many HF rigs made around the 1990's including the IC-781. Unfortunately I only took the time to fully document the procedure for the TS-940S. If anyone has one of these and is interested in the mod with pictures, Just send me a message trough this site. As good as the FT-101 series was on AM, the modified TS-940S is much better in terms of power and newer features.
The radio will easily modulate a 50 watt carrier to over 100% positive peaks. When the radio was undergoing this mod at one point I had the response opened up from 1 Hz to 100 KHz! I later bypassed the input to the audio amp to knock the high end down to just below 10 KHz to keep things within reason.
The mod has worked flawless in the 940's as I did about 7 of them for people a decade ago. All switching is done automatically off the mode switch in AM. The only function that is lost is the AM monitor in TX. That could be restored by adding a detector, I just never bothered. The mod is clean, nothing is hacked and it can be easily reversed although you'll never want to. By adding one switch the mod can be switched out on AM to compare the before and after effects of modulating the RF stage or IF stage.
  #47
Old 10-22-2009, 09:28 AM
bigred222's Avatar
Key Up City Radio
bigred222 is on a distinguished road
Default
Quote:
Originally Posted by Radio Tech View Post
The 101 will have better sounding AM audio. I do not thisk I have seen a modern day rig that has good AM audio nowadays. Wonder why?
Most of the AM crowd runs the old stuff with big amps. Legal power of coarse.
then you obviously havent heard shockwaves kenwood
__________________
Galaxy DX2547
Midnight Special 700
Iota DLS-90
Antron 99
Cobra 21Ltd Switch kit special
ADX-202
CDX-202
WWW.CBJUNK.COM Come here for fine CB Chatter
  #48
Old 01-20-2010, 03:10 PM
Junior Member
mexloco is on a distinguished road
Default ft101 e
i love mine works very good number3 channel 19am
  #49
Old 01-21-2010, 04:40 PM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt is on a distinguished road
Default
I must have slept thru this thread. Modern solidstate gear sounds crappy on AM for one very simple reason,they don't generate AM like they used. Good sounding AM is full carrier double sideband while the new gear today generates AM by using a full carrier and only one sideband, usually the upper side band, since both sidebands are unnecessary to convey the audio content.The result is a narrower "pinched" sounding signal that lacks the presence of full carrier double sideband AM. Whether the final is high level modulated or low level is irrelevant. Most people seem to confuse those terms and believe that low level modulation means something less than 100% when in fact it simply means that an RF stage "lower" in the chain, like a driver stage, has the modulation applied to it instead of the final stage. It amounts to the EXACT same thing as a "highlevel" modulated radio with an amp after it.
__________________
Light travels faster than the speed of sound, this is why some people tend to appear bright, until they decide to speak.
  #50
Old 01-21-2010, 04:55 PM
Senior Member
Default
Quote:
I hate to disagree with anyone who has a kilowatt but this is plain incorrect.
Some military and marine rigs use one sideband with carrier. Almost all riceboxes use double sideband in the AM mode. There are only a few exceptions. The AM produced by a properly setup ricebox is AM just like an 807 modulated by a pair of 6L6s with. It is indistinguishable on a scope showing an envelope pattern.
One sideband with carrier will not produce low distortion with the diode detector used in 98% of hammy receivers.
Warmed over riceboxes are among the best sounding and least distorted AM transmitters in the Northeastern U.S.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
