Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > HF Bands and HF Rigs
Amateur Callsign Lookup
Enter Callsign:
Kenwood TS-440S signal meter problem
Reply
  #1
Old 10-17-2009, 11:22 AM
Junior Member
Pelltom is on a distinguished road
Default Kenwood TS-440S signal meter problem
Hello there
Is it correct that if im listening AM station on Fm Mod signal meter is bounching
like 3 or 5 then i turn to AM mod it`s shows only s 0.5 or 1 ?
Worldwide Radio Forum
  #2
Old 10-17-2009, 10:18 PM
mackmobile43's Avatar
Prestigious Member
mackmobile43 is on a distinguished road
Default
Quote:
Originally Posted by Pelltom View Post
Hello there
Not sure if it's normal for the 440 but my 430 does the same thing and I would imagine that there is a logical reason but I cannot answer that.
__________________
I U 212
  #3
Old 10-17-2009, 11:01 PM
Supporting Member
W5LZ is an unknown quantity at this point
Default
I'm not sure if I'm understanding the question correctly but, this is one explanation for what you're seeing.
An AM signal's power changes almost constantly to some extent. That's why you see the 'S' meter wiggle. Am FM signal has a constant power level, what changes with modulation is the frequency, which stays centered on one particular frequency. That FM signal on an 'S' meter will show a constant power level.
Make sense?
  #4
Old 10-18-2009, 01:14 AM
74IN's Avatar
Supporting Member
74IN is on a distinguished road
Default
What mode is the transmitting station using?
__________________
XDX74
  #5
Old 10-18-2009, 01:16 AM
74IN's Avatar
Supporting Member
Default
I'd guess our 430's are very similar to a 440.
Just more memory channels and a different face.
__________________
XDX74
  #6
Old 10-18-2009, 05:34 AM
Junior Member
Default
Quote:
it`s using AM modulation....im just wonder why so big difference...
  #7
Old 10-18-2009, 09:21 AM
Beetle's Avatar
Senior Member
Beetle is on a distinguished road
Default
W5LZ answered that question.
__________________
If you're like everybody else,
you're about average.
73 de K7KBN
  #8
Old 10-18-2009, 10:12 AM
Supporting Member
Default
And just for grins...
You can 'make out' FM when in the AM receive mode. Have to do the tuning just right, and it'll never be very clear/plain, but it can be done. Doesn't work the other way around though. At least I couldn't make it work. Too easy to just punch a button to FM. Oh well.
Another just for grins.
The '430 and '440 were similar, but not just a 'new box'. Big differences in how things were accomplished. Some aspects were better with the '440, some weren't. So what else is new?
  #9
Old 10-18-2009, 10:33 AM
Senior Member
HiDef is an unknown quantity at this point
Default
Your rig is probably working normally.
Hammy rig's S meters are non-linear on FM due to the limiter stage in the I.F. amp. That stage is there to remove the AM response in an FM system. There is a lot more gain because of this. The S meter responds to AGC voltage. That voltage will be non-linear on FM due to the limiter.
If you wish to have relatively more accurate S meter readings for experiments use the rig on AM receive to take the reading even if it is an FM signal.
All this stuff is well covered in older ARRL handbooks. FM techniques are a lot different than other phone modes.
The 440 and 430 don't share much in terms of layout. The 440 has an additional 455 khz I.F. stage.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
PROBLEM WITH ROTOR BOX DIRECTION METER. TonyV225 Amateur Radio Antennas 11 11-03-2008 10:15 AM
Interesting reading, datsun66 General Ham Radio Discussion 3 08-16-2007 09:16 PM
Browning MarkIII Transmitter - Meter Problem Space Cadet CB Band and CB Radios 6 09-09-2005 11:20 PM
bulldog wattmeter 211 in tha mag Meters, Mics & Other Accessories 15 01-23-2002 07:22 PM
Powered by vBulletin®
