Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > HF Bands and HF Rigs
Amateur Callsign Lookup
Enter Callsign:
FT-900 Negative Swing on AM ??
Reply
  #11
Old 10-26-2009, 01:12 PM
Junior Member
jwhawg is on a distinguished road
Default
Well thanks for going over it with me. Sometimes another brain involved is enough to figure out most stuff. I hope this problem looks familliar to someone.
I'll keep trying. May need to find an old BA for am I guess. Anyway, have a good day and 73,
Joe K0TRT
jwhawg
Worldwide Radio Forum
  #12
Old 10-26-2009, 01:28 PM
TonyV225's Avatar
Senior Member
TonyV225 is on a distinguished road
Default
Thats A OK thats what were all here for but now that you got me thinking and curious Ill have to watch because this also has me stumped and its worse when you dont have the radio infront of you if you see what Im saying. 73's
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #13
Old 10-26-2009, 01:37 PM
Junior Member
Default
I know what you mean Tony and thanks again. I'll let you know what I find.
Joe
  #14
Old 10-26-2009, 05:06 PM
Bionic Chicken's Avatar
Senior Member
Bionic Chicken is an unknown quantity at this point
Default
If you use an external "peak" reading wattmeter does it still show to be backing up? On some radios I have had to play with the mike gain and compressor (if it had one) in order to get any forward movement out of it. Like it has been already stated most of the time if you lower the dead key to 10 to 15 watts they would move forward if only a little bit. Some of them can be a PITA to get set right but once you do...............
__________________
BC
  #15
Old 10-27-2009, 12:04 AM
Senior Member
moleculo has disabled reputation
Default
My Bird43P Peak reading meter always shows backward deflection on my Icom 746 Pro. I have never figured out why it does this. The active peak reading meter in my Ameritron tuner does not show this. My only guess is that some combination of mic, rig, and other audio gear causes the phase to be negative and somehow the meter reacts to this. Keep in mind that I have no idea whether this could occur...it's purely speculation on my part.
  #16
Old 10-27-2009, 01:13 AM
TonyV225's Avatar
Senior Member
Default
I threw the towel in on this one to like I was saying to him earlier today I have seen this but without the radio infront of me IM LOST!!
__________________
  #17
Old 10-27-2009, 02:33 AM
Junior Member
Default
Yes it does swing backwards on a bird peak reader. And every other I have tried. I was also hoping that it was just a meter action, or reaction, but I send a negatively swinging signal to other receiving radios. Staions say I have great audio, but swing from say s-9 back to s-7 or whatever.
  #18
Old 10-27-2009, 02:37 AM
Junior Member
Default
Quote:
Was wondering if you had transmitted on am with your 746? Just curious as to seeing if it also swings backward to receiving stations?
  #19
Old 10-27-2009, 04:31 AM
Junior Member
Alcahuete is on a distinguished road
Default
Very interesting...new member and happened to find this site after a Yahoo search for something totally unrelated. What do you know, this thread was right near the top.
I have had a very similar issue with my radio (FT-900AT) for quite a few years. The funny thing is that this happened right after a visit to the Yaesu factory (in Cerritos) for some warranty work. The radio for whatever reason blew a resistor and capacitor (I believe, though I don't have the exact report on-hand right now), which ultimately ended up with nothing but RF and no audio at all. After getting the radio back, it appeared to be backswinging on AM as well.
I haven't tested it side-by-side with another radio in years, so I don't remember if it was actually swinging backwards on another radio's S-Meter. The ammeter on my power supply shows a good drop in amperage when using the radio, from deadkey to modulation, but after hooking it up to a watt meter, I got some interesting results. My peak-reading watt meter showed that it would deadkey around 40 watts and swing up to about 130 watts when talking. The radio itself puts out about 130 watts on all other modes as well.
So I guess I'll sit it side-by-side with another radio one of these days and see what the S-meter is saying.
Interesting thread. Nice to finally come across a discussion on this.
Last edited by Alcahuete; 10-27-2009 at 04:33 AM. Reason: Clarification on radio model
  #20
Old 10-27-2009, 08:21 AM
Junior Member
Default
Well, Now we might be getting somewhere! The very same rig (FT900AT). Please, if you can, take some time and see if it really is sending a backward swinging signal to another radio. Post what you find. And thanks a million!
73 Joe K0TRT
jwhawg
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
your favorite CB myth , lies and legends . BOOTY MONSTER General CB Services Discussion 74 10-23-2009 07:07 PM
Super Swing and That Channel 6 Sound ButtFuzz RADIO AND RADIO RELATED MODIFICATIONS 2 06-10-2009 09:45 PM
Magnum Delta Force low am modulation and swing 528kasanoba Tech, & Repair 3 12-01-2008 04:48 PM
Icom IC-706MKIIG Reverse Swing broncoman529 HF Bands and HF Rigs 18 05-10-2008 10:08 PM
Update Proper way to make a Tube Amp Swing and Prolong Tubes High Miler Amplifiers 3 11-23-2005 03:27 PM
Powered by vBulletin®
