i would wait for the next gen design for either the 3000 or 5000.
Recently it was disclosed that they put out a spurious image a bit down the band from the main signal. At 100W it's not much of an issue, but if you are running a
kW+ it causes a horrendous amount of interference.
This was brought to their attention and they have ignored it. Evidently it's a fundamental (bad pun) flaw that requires a re-design. There is a software kludge/patch that is out there to null the image on a specific band, but it's not automated so each band change requires you to do the calibration again. This patch isn't in the main software release however....
This issue may go back to the SDR-1000 design too, but I'm not sure there.
