Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > HF Bands and HF Rigs
Amateur Callsign Lookup
Enter Callsign:
Hi-Fi AM transmit for your TS-940S
Reply
  #11
Old 11-05-2009, 02:51 PM
Shockwave is on a distinguished road
Default
QRN, there is a huge difference between the iron used in the broadcast transmitters you mention and the "communications quality" iron used in ham boat anchors. I agree 15 Hz to 12 KHz is good response but I can get 1 Hz to over 50 KHz without even trying hard on the 940. I have to cut the high end off because it's too excessive. The real deal is the positive audio peaks with the 940. It's possible to get 200% positive peaks although I don't run much past 125%.
Plate modulated transmitters usually can't come close without flashing the spark gap on the mod iron. Plus there is something to be said about obtaining this type of audio from a modern transceiver with digital display, no drift, no tune output stages, auto antenna tuner, and memory channels.
Worldwide Radio Forum
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Alinco DJ-G7 Extended Transmit Mod Video moleculo RADIO AND RADIO RELATED MODIFICATIONS 1 08-10-2009 09:20 PM
Cobra 29 LTD Classic Problems : Weak Receive, No Transmit office888 CB Band and CB Radios 6 06-09-2009 08:00 PM
Cobra 29XLR No Transmit Space Cadet Tech, & Repair 1 08-31-2005 07:57 AM
Galaxy 959 going crazy /receive no transmit ??????? Switch Kit Tech, & Repair 4 05-27-2005 01:11 AM
rci 2980 problem no transmit on am bigboy30 Tech, & Repair 1 12-31-1969 06:00 PM
Powered by vBulletin®
