Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > HF Bands and HF Rigs
Amateur Callsign Lookup
Enter Callsign:
Kenwood TS50 Problem
Reply
  #1
Old 06-06-2010, 05:31 AM
Junior Member
VE3UG is on a distinguished road
Default Kenwood TS50 Problem
When first powered up (cold start), my TS-50 has no receive and the S-meter shows full scale!
This occurs for about 30-45 seconds and then the S-meter slowly recedes and audio is received.
Everything else seems to be OK!
Any solutions?
Thank you
Rick
  #2
Old 06-06-2010, 05:53 AM
Radioman1 is on a distinguished road
Default Kenwood problem
Have you done the full microprocessor reset as described
in your manual ??
Let us know.....Mac
  #3
Old 06-06-2010, 09:18 AM
TonyV225's Avatar
TonyV225 is on a distinguished road
Default
Thats odd my wifes TS-50 and matching AT-50 Tuner have been trouble free for years!!I would do as mentioned above and do a full reset.
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #4
Old 06-06-2010, 02:09 PM
Junior Member
Default
Full reset did not change anything!
Thanks for suggestion!
Rick
  #5
Old 06-06-2010, 03:15 PM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
It's been quite a while so I can't tell you exactly what the problem is, but I've seen it happen. It has to do with a voltage regulation problem, or a DC/DC regulator or whatever the @#$ thing is called. I can tell you that unless you are very very good at it, don't try correcting it your self. Send/take it to someone who can deal with it.
I've had two TS-50's, the first had that problem, the second didn't. That was the only thing that ever gave me any trouble with either of them (aside from me doing something I shouldn't have done to start with ).
  #6
Old 06-07-2010, 09:52 AM
Junior Member
Default
That appears to be the symptom/solution!
Now does anyone know which regulator?
Thanks,
Rick
  #7
Old 07-25-2010, 03:55 PM
packrat's Avatar
Senior Member
packrat is on a distinguished road
Default
I know that I am late to the party, but change out the memory battery.(2032?)
__________________
Incentives are important.....I learned that in rehab!
  #8
Old 07-30-2010, 08:53 PM
Junior Member
AH6KW is on a distinguished road
Default I have exactly the same TS50 problem!
I've been using the TS50S for a couple of years, and the exact problem described by VE3UG just developed a few weeks ago - at first intermittently, now every time I power it up from a cold start. The delay before normal reception varies depending on band and mode, but it takes a maximum of 30-45 seconds before settling down to otherwise normal operation. It doesn't seem to happen (or at least not for as long) if it's been powered down for less than a few minutes, so warmup is somehow involved.
If the audio volume is at or above normal level, there's also often a loud feedback-type squeal that only disappears when the volume is turned all the way down or after normal operation resumes. The squeal occurs with or without headphones. Keying the transmitter cuts off the squeal and switches the s-meter to apparently normal transmit operation in all modes. Receive still does not work until after the noted delay.
This isn't a serious problem for my normal operation, but it seems to be progressing - i.e. it's becoming more consistent and the delay time seems to be slowly increasing. I assume that whatever is causing the problem - a dc-dc converter sounds like a likely candidate - will probably fail sooner rather than later and may damage other components.
I'm hesitant to reset the processor unless it's likely to fix the problem - which it didn't do for VE3UG. I can change the battery, but I don't understand how that might help the problem.
I look forward to additions to this thread, hopefully some with specific solutions for the problem.
Aloha from Kona,
AH6KW
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
KENWOOD TM241 PROBLEM ve3mud VHF/UHF Bands and VHF/UHF Rigs 0 02-13-2010 08:36 PM
kenwood tk-840 problem GLR VHF/UHF Bands and VHF/UHF Rigs 6 02-05-2008 08:05 PM
Kenwood TS-440s Problem JustinDePolis2 HF Bands and HF Rigs 3 12-13-2004 09:37 PM
Icom 706 mkIIg or Kenwood ts50 Skip Talker HF Bands and HF Rigs 2 10-22-2002 02:28 PM
Info on Kenwood TS50 battery! Marconi HF Bands and HF Rigs 5 05-02-2002 04:19 PM
Powered by vBulletin®
