Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > HF Bands and HF Rigs
Amateur Callsign Lookup
Enter Callsign:
External Speaker FT-857
Reply
  #1
Old 08-02-2010, 03:46 PM
W1MSG's Avatar
Now W1MSG
W1MSG is on a distinguished road
Default External Speaker FT-857
Is there an undocumented feature, or something I overlooked, to having both the internal speaker and the external jack live ? I would like to hook the external up to a recorder and still hear the internal speaker.
Thanks
__________________
Craig, W1MSG
TS-2000 / G5400B / Gulf Alpha 2mCP, M2 70cmCP Beams
Flex 5000 w Audio Rack / Palstar AT2KD / Commander HF-2500 Amp / AKG Perception 220 Mic
Wouxun Dual Band HT
  #2
Old 08-02-2010, 04:07 PM
Senior Member
Qwazyone is on a distinguished road
Default
I don't think there is, the internal speaker is probably wired in series with the external jacks, so that when an external is used the internal speaker doesn't work. One possibility may be the data jack on the back, its strictly a line out(volume control has no affect) but connecting a recorder up to the 1200bps(audio out) and ground may give you something to record. My PS2 keyboard connector didn't work, only had 4 wires for the 6 pins and the 1200 out was one of the wires missing. A simple splitter should give you the ability to record and listen on a headset.
Have you tried listening to the SSB sats with the 857 and the arrow yet?
  #3
Old 08-02-2010, 04:23 PM
Moleculo has disabled reputation
Default
Doing it with the ACC jack on the back is the way to do it. Just get or build a PC interface for the radio and you'll be all set up to do what you're talking about.
  #4
Old 08-02-2010, 05:07 PM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt is on a distinguished road
Default
Agreed. I have the 857 and if you want to listen to an external speaker it cuts off the internal one. You need to use the data jack on the back to pull off audio. All you need is a simple cord wired to an 8 pin DIN jack on one end and whatever he recorder takes on the other. As stated above, that level is fixed but should be suitable for most any recorders using a line input.
__________________
  #5
Old 08-02-2010, 05:56 PM
0x33f is on a distinguished road
Default
Straight from the manual
Connection of a tape recorder or other such receiver accessory is easily accomplished by
using the DATA jack’s Data Out (1200 bps) terminal (Pin 5) and Ground (Pin 2). The
audio output is fixed at 100 mV, with an impedance of 600 Ω.
  #6
Old 08-02-2010, 08:22 PM
TonyV225's Avatar
TonyV225 is on a distinguished road
Default
I never even seen that in my manual!!! LMAO!! Thats actually pretty cool.
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cobra High Gear S500 external speaker Marty Meters, Mics & Other Accessories 2 05-22-2007 02:29 AM
External Speaker? skirk55 CB Band and CB Radios 6 12-27-2006 11:22 AM
external speaker ?'s jeffrice6 Meters, Mics & Other Accessories 11 09-11-2005 12:36 PM
external speaker feedback spiderman General CB Services Discussion 3 08-11-2005 11:09 AM
Favorite external speaker? WalshU Meters, Mics & Other Accessories 40 05-01-2003 07:15 PM
Powered by vBulletin®
