WorldWide Radio Forum
Go Back   WorldWide Radio Forum > Amateur Radio Related > Home Brew & Mods
Notices
Home Brew & Mods
Show off, get help, or do a step-by-stop on a home brew project.
Reply
  #21 (permalink)
Old 03-10-2008, 03:53 PM
mackmobile43's Avatar
Proud Pro-White American
mackmobile43 is on a distinguished road
Default
Quote:
Originally Posted by GRTS View Post
The plastic mounting screws on the mosfets will be a problem.
maybe they're teflon and yes dwb I too think it's seeing bias voltage whenever the power is attached.
  #22 (permalink)
Old 03-11-2008, 05:57 AM
Crusher is on a distinguished road
Default
I used the plastic screws, because the holes are to small for standard insulators. I need to install a relay/switch so that yes the bias will be turned off when in standby. First mosfet amp I ever built, so yeah I have a few items to address yet.
  #23 (permalink)
Old 03-11-2008, 06:02 AM
Default
The #4-40 screw insulators is what i was referring to. They are too big for hole in Mosfet. As these need to be electrically isolated from heatsink.
  #24 (permalink)
Old 03-12-2008, 03:21 PM
Default
Last night, I installed a relay so that when keying circuit is activated, it turns on relay and supplies voltage to biasing circuit. That way there is only voltage applied when circuit is transmitting. Anymore ideas or suggestions are welcome.
Crusher
  #25 (permalink)
Old 03-15-2008, 12:33 PM
Default
Quote:
Crusher
  #26 (permalink)
Old 03-15-2008, 03:25 PM
Default
Thanks 43, never really thought of installing it, did not seem like a problem at time but as i said, it was something i overlooked. That amp likes about a 2 watt DK and works nicely. Put about 12 hours on it now and seems to work fine. But I know what GRTS meant about nylon screws, as they heat up, plastic tends to expand and eventually pressure is taken off of transistor and can't dissipate heat nearly as well and poof. Magic smoke. LOL
  #27 (permalink)
Old 03-15-2008, 04:01 PM
Default
Someone had told me at one point that IRF550A mosfets would make for a nice small amp. Boy were they wrong as so was I for not looking at datasheet. Just in case anyone else was thinking about trying something slightly bigger in the same family so to speak.
  #28 (permalink)
Old 03-15-2008, 07:09 PM
Default
The issue with the screws can be solved by drilling the holes of the transistor tabs lager and using the teflon shoulder washers or by placing a flat metal strap across the transistors with a single screw through it to the heat sink.
  #29 (permalink)
Old 03-17-2008, 01:08 PM
Senior Member
4600turbo is on a distinguished road
Default
GRTS, Galaxy has a model called 98VHP. It has 8 IRF520's as final section. Might want to take a look at that as well. Going to try a few other projects with IRF550's and IRF35X series. Anyone know how I can post a pic of this project?
Why use MosFets. When you could put in 4x2879's and get quite a few more watts out of it.
Owner of the World biggest Galaxy radio.
4X2879's 550-600watts. PEP.
  #30 (permalink)
Old 03-18-2008, 03:39 PM
Default
LOL, if I want a big box I will build a big box for myself. But I have more fun just building and experimenting with the stuff. Trying new stuff out.
Reply
Bookmarks
Tags
irf520 mosfet
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
