WorldWide Radio Forum
Go Back   WorldWide Radio Forum > Amateur Radio Related > Home Brew & Mods
Notices
Home Brew & Mods
Show off, get help, or do a step-by-stop on a home brew project.
Reply
  #31 (permalink)
Old 03-18-2008, 09:44 PM
Senior Member
4600turbo is on a distinguished road
Default
Quote:
Originally Posted by Crusher View Post
LOL, if I want a big box I will build a big box for myself. But I have more fun just building and experimenting with the stuff. Trying new stuff out.
That's cool. Your building a box with MosFets. God knows why, but expermenting is fun.
I just thought you wanted a bigger radio.
Still the owner of the biggest Galaxy radio in the world.
550-600 watts PEP. Hope to stay that way for awhile.
  #32 (permalink)
Old 03-19-2008, 01:27 PM
Crusher is on a distinguished road
Default
If i wanted big numbers, I would keep to a stock radio, and then get 2-3 amplifier stages to get some big numbers. LOL. Buying one of those big radios with all the extras is a waste. Unless you like all those little toys on the export radios. I like a standard SSB chassis or one of the true amatuer radios. Not an export radio. From my dealings with them in the past, they are overpriced garbage. Just my 2 cents though.
Crusher
  #33 (permalink)
Old 03-21-2008, 03:52 AM
Default
I did a little more testing using the irf520A and the IRF520N. I get a noticeable difference of almost an additional 8-10 watts average on a bird. One other difference was that the input was alot harder to get a low SWR. i got it down to a 1.5 on the input with the N type were as i had a 1.05 on the input with the A type. This was using my LP-100. Just thought someone would like to know this. I believe that the N type has a higher capacitance that is harder to cancel out.
  #34 (permalink)
Old 03-21-2008, 06:01 AM
AudioShockwav's Avatar
Senior Member
AudioShockwav is on a distinguished road
Default
Thanks Crusher.
Kudos for sharing what you are learning.
__________________
Radio-active
http://sohowww.nascom.nasa.gov/data/realtime/javagif/gifs_thumb/20080120_1300_eit_171.gif
NASA/SOHO
  #35 (permalink)
Old 03-21-2008, 08:34 AM
Galaxy Tech
GRTS is on a distinguished road
Default
You didn't say which mosfet "A" or "N" you saw higher power on.
Also the datasheet shows the IRF520N has lower input capacitance than the IRF520A however datasheets are not all created equal.
  #36 (permalink)
Old 03-22-2008, 02:08 PM
Default
The IRF520N is the mosfet that i am seeing a higher ouput level. I did get the input SWR down significantly. Down to about a 1.1:1 SWR I could have gotten it lower, but as the radio swings forward, the SWR would approach closer to a 1.3:1 SWR which, still is pretty good. I may have to put some kind of padding /swamping circuit on the input to decrease the input drive. It works great, it dead keys approximately 25 watts and swings 45 almost 50 watts. using a 50 watt slug. While I was testing it though, I have a thermal remote reader for measuring temperatuers at a distance. I was reading somewere in the vicinity of 180-190 degrees F. Just thought I would metion that as trying to get the few extra watts may cause a much shorter life span of the transister.
  #37 (permalink)
Old 07-14-2008, 06:17 AM
Rf Engineer
freecell is on a distinguished road
Default
the max junction operating temperature for the irf520 is 175 C or 347 F.
Reply
Bookmarks
Tags
irf520 mosfet
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
WorldWide Radio
