Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > Home Brew & Mods
Amateur Callsign Lookup
Enter Callsign:
RF Sampler
Reply
  #1
Old 01-21-2009, 10:19 AM
Senior Member
moleculo has disabled reputation
Default RF Sampler
Here's a homebrew RF sampler that's easy to build. I use this to connect to an Oscilloscope and Frequency counter (T off the BNC plug) It's pretty straight forward to build and the pictures pretty much explain themselves.
Here's the inside...note the resistor and the ferrite core.
Worldwide Radio Forum
  #2
Old 01-21-2009, 12:25 PM
Sonwatcher's Avatar
Senior Member
Sonwatcher is on a distinguished road
Default
2k resistor ?
__________________
http://www.haminfobar.co.uk
  #3
Old 01-21-2009, 05:28 PM
Captain Kilowatt's Avatar
Administrator
Captain Kilowatt is on a distinguished road
Default
Quote:
Originally Posted by Sonwatcher View Post
2k resistor ?
You missed it by a power of ten and then some. It's a 100 ohm resistor. Brown-black-brown.
__________________
Front/back ratio comes from the antenna. Forward gain comes from the wall socket.
  #4
Old 01-21-2009, 05:32 PM
Sonwatcher's Avatar
Senior Member
Default
Ok, read the bands as red . Thanks !
__________________
  #5
Old 01-21-2009, 05:44 PM
Administrator
Default
Here's another good one to use Every toolbox needs one of these
and another that is in the ARRL Handbook is quite handy as well. It is made from copper pie and a copper Tee and end cap. I can't find a pix online anywhere but I will try and find my old one I have here somewhere. It is great for VHF and UHF pickup but will work on HF as well.The great thing is that it does not upset the SWR on V/Uhf.
__________________
  #6
Old 01-21-2009, 05:46 PM
Administrator
Default
That's OK. I said it was a 200 ohm resistior when in fact it is a 100 ohm unit. Corrected above.
__________________
  #7
Old 03-08-2009, 03:08 PM
Senior Member
Cityboy is on a distinguished road
Default
I also did this RF sampler and works great with my B+K 35mhz osc. I also did one more thing to make it convient to hook my frequency counter on and sample at the same time. I drilled another hole in the box and put another bnc connector with another 100ohm resistor that connects on to the same point as the one for the scope. I then drilled a hole in the side of my Wawassee jb-1004 freq counter and put a bnc connector in the case and grounded it and ran a wire from the center terminal of the bnc and connected onto the wire that samples frequency that went around the bridge wire between the coaxial input of the freq counter. So now I don't have to have 2 coax jumper cables; 1 going from the transmitter to the freq counter and the other to the dummy load. It only requires 1 bnc jumper cable to the one I put on the side of the counter and it does a great job. I checked against my other jb-1002 fcm Wawasee and it is dead on in its sampling.
  #8
Old 07-08-2009, 10:00 PM
Junior Member
galyndavis is on a distinguished road
Default great idea!
I bought the set of these off ebay, one for after the radio and another after the amp . I paid ( i was ashamed when i took the covers off) around 200 dollars for the set. Thanks for the post ....it will save others from paying too much for something this easy to build. Post like yours help folks to achieve their goals without going bankrupt doing it. There was a time when radio guys made all their tools.....very cool.
thanks for sharing,
galyn davis
  #9
Old 07-09-2009, 08:18 AM
Administrator
Default
I have an MFJ-264 dummyload. I installed a small toroid over the wire going from the RF connector to the load resistor and wound it with a half dozen turns of wire. I connected this to a BNC jack that I mounted in the lower right corner of the case. This allows me to make measurements without having to insert anything inline as the dummy load is connected to an MFJ-1700B antenna/transmitter switch.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
