Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > Home Brew & Mods
Amateur Callsign Lookup
Enter Callsign:
Antenna Project
Reply
  #11
Old 04-27-2009, 10:06 PM
Senior Member
moleculo has disabled reputation
Default
Nice project! To the front page with you!!!
Worldwide Radio Forum
  #12
Old 04-28-2009, 05:53 AM
JDemoret is on a distinguished road
Default
Thanks for the advise and comments. I'm going to leave it where it is for a couple of days to see how it does in some weather and to get caught up on the honey do list . Working on getting the ground radials ready to attach. Will post the pogress as it goes along.
John
  #13
Old 05-01-2009, 03:39 PM
Default
Got back to working on the antenna today and got the ground radials attached and the matching circuit hooked up and results were good .
Channel 1 1.4:1
Channel 20 1.3:1
Channel 40 1.2:1
Putting in about 22 watts.
Did not have to use the coax capacitor, actually results with it on were really poor. Tap point on the coil was typical, about 2 turns down. First contact was about 50 miles north of me with the feed point of the antenna about 6ft. off the ground .
Next job is to get it on the house and about 35ft. up.
More to come.
John
  #14
Old 05-05-2009, 05:05 PM
Default
Well, for the last week or so I've been putting the antenna through it's paces and doing some tweaking and getting all weather-proofed getting ready to get it up on the house in it's final position. Here are the final results:
Radiator length: 23ft.
4 ground radials at 102" each.
SWR readings:
Channel #1: 1.2:1
Channel #20: 1.1:1
Channel #40: 1.0:1
I think I could fool around and fool around but this is about as practically close as it's going to get and so far with the feed point only about 6ft. off the ground I've gotten some good reports.
Thats all for now. Next step is an antenna raising.
John
  #15
Old 05-05-2009, 08:19 PM
HomerBB's Avatar
Senior Member
HomerBB is on a distinguished road
Default
Great!
How high you gonna put it?
  #16
Old 05-05-2009, 10:19 PM
RickC.'s Avatar
Hopeless antenna junkie
RickC. is on a distinguished road
Default
Quote:
Channel 1 1.4:1
Channel 20 1.3:1
Channel 40 1.2:1
More to come.
John
Hey John,
I'm coming to the party late on this one (you snuck this by me while I was tied up at Talladega), but good stuff! I was wondering what you were going to do with this that you needed an LC circuit at the base... But right, you shouldn't need a capacitor across this one. And your coil looks better than the one I made with the runny epoxy!
I look forward to seeing more pics and hearing how this performs when you have it up in the air.
Rick
  #17
Old 05-05-2009, 10:48 PM
Default
Thanks Rick. So far the antenna has performed alot better than expected and I'm really excited about getting it up in the air.
Homer, I picked up 40 ft. of 1 1/4 inch EMT and I'm going to try to use it all, will let you know how it goes once I get a full day to work on it and some good weather.
John
  #18
Old 05-09-2009, 09:51 PM
Default
Finally got the antenna up in the air. Had to settle for 32ft. at the feed point but that's alot better than 6ft. where's it's been for the last two weeks. Had to replace the bottom section as it snapped in the first attempt to get it up but was able to fix it and eventually got it all in place.
Final SWR:
Channel 1: 1.4:1
Channel 20: 1.2:1
Channel 40: 1.1:1
The antenna is reading "short" and I haven't messed with the tap point on the coil yet and am not sure if it would change anything and I need to double check the angles of the ground radials to make sure their at 45 deg. and again not sure if it would change anything but those are the only options I have unless I take it completly down and add more to the radiator. Oh well, it's all good.
John
  #19
Old 05-09-2009, 10:02 PM
Supporting Member
W5LZ is an unknown quantity at this point
Default
About the antenna reading 'short'/shorted(?).
Depending on how that coil is connected, it should read as being shorted at DC. That doesn't mean it will be a 'short' at the frequency of use. I can't tell from the picture (and am too lazy to go back through the thread), but if the bottom of the coil is connected to ground on the SO-239, then it is a DC short, and is still not a problem at the frequency of use. If the bottom of that coil is connected to the SO-239's center pin, then it isn't a 'matching' coil, it's a 'loading' coil. If it shows a short this way, then there is a problem somewhere.
  #20
Old 05-09-2009, 10:43 PM
HomerBB's Avatar
Senior Member
Default
Perhaps he's referring to the SWR being higher on 1 than forty which by some is said to be short and can be fixed by lengthening the vertical whip on an antenna. . .
BTW, it looks good.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
