Quote:
Originally Posted by moleculo MAX-GAIN SYSTEMS, INC. : Fiberglass Price List
I bought some from these guys a while back. They have every size, type and length. You don't need 2" in diameter for your project...I bought some 1" diameter solid stuff that is unbelievably strong
BTW, these guys also have fiberglass push up masts. |
I was just thinking of the ID size of the pipe.
It's actually 1-1/2" but I thought I could turn down some 2" part of the length and let the rest stick out.
Last night (while not sleeping) I figured I could shove a piece of 1-1/2"
something down the inside of the mast and let about a foot stick out and then get some kind of plastic pipe that was 2" OD, slide the plastic over the
whatever and clamp the vertical element to that.
I think Marconi and the others that suggested I had induction problems between the mast and element hit the nail on the head. I think the increase of SWR with the increase in power suggests that too
From an earlier experiment I have a piece of 1-1/2" wooden closet rod (4') that I can slide inside the mast and lag bolt. Now I just need to find some plastic pipe that is 1-1/2" ID and 2" OD (apprx) so I can use my original ($) u-bolt mount for the vertical. But I can always figure out some shims if nothing else
Thanks for the link to the fiberglass rod place. Wish they sold less that 8' chunks. Probably a third of that would do me
