Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > Home Brew & Mods
Amateur Callsign Lookup
Enter Callsign:
Ramsey PR40 440Mhz Preamp kit
Reply
LinkBack (2) Thread Tools Display Modes
  #11
Old 08-25-2009, 06:44 PM
Senior Member
moleculo has disabled reputation
Default
One quick comment...it didn't take all that long to drop it down to under 16v...especially if you accidentally leave it on over night...
Worldwide Radio Forum
  #12
Old 08-26-2009, 01:57 PM
Junior Member
ve3-radio is on a distinguished road
Default
Thanks for checking those voltages. Yeah, I am not sure why my Vbe is so high. The resistors are of correct value R1=470 Ohm and R2=97K (I do not think +/- 3K would matter on 100K resistor) and placed correctly on the board. The transistor in the kit is C2570, placed correctly. No shorts, no opens. Oh well...
  #13
Old 08-28-2009, 08:58 PM
Senior Member
Default
I worked AO-51 tonight with the preamp inline. This was a 41 degree pass for me. One thing I noticed this evening is that with the preamp on I started picking up the satellite almost immediately on the horizon. In the past, I was never able to do this...I didn't start picking it up until it had some elevation on my location. I switched the preamp off and on a few times to verify and was really pleased at the difference it made. I could hear it through it's entire pass.
  #14
Old 08-28-2009, 09:54 PM
TMI TMI is offline
Junior Member
TMI is on a distinguished road
Default
Quote:
I worked AO-51 tonight, too. Preamp kit is in the mail. Did you pick up your project box and 9V battery clips locally, or do you have a secret source
...Tom
  #15
Old 08-29-2009, 10:15 AM
Senior Member
Default
I got the project box and battery clips at Fry's Electronics. The box had mounting posts (for screws) that were in all the wrong places, so i had to use a dremel tool to cut them out. I saw some project boxes at the electronics swap that would have worked better. The main board is just hot glued to the project box. I was a little hesitant about doing it this way, but it seems to be working out OK. At least that way if I have to pull it back out to replace something, it won't be too difficult to lift off the box. The battery clips are velcro'd to the board. I did it that way because the clips are REALLY strong and it can be tricky to get batteries in and out of in that small space. By making the battery leads a little longer and mounting them with velcro, I can lift them out and use two hands to do it. It seems to be working.
BTW, did I work you? I don't have a voice recorder so I'm not even trying to keep a log.
  #16
Old 08-29-2009, 10:29 PM
TMI TMI is offline
Junior Member
Default
Negative. The passes I've been working lately have picked up So. Cal to Alaska. I need to work some lower angle passes to pick up more mid-west and east coast contacts. Farthest to date from western Washington has been Ohio for me.
I'd also like to get up on a hilltop and work a low pass to the west, and see if I can hear any Hawaii stations.
This is just a whole lot of fun with 5 watts
Tom / W3ROK
  #17
Old 08-30-2009, 10:28 AM
dudmuck's Avatar
Senior Member
dudmuck is an unknown quantity at this point
Default
Tuning up this preamp could be easier if they included a variable capacitor for the RF input C2.
But for a $15 kit, i doubt that would be practical.
i'm not sure if they use the 2SC2498 or the 2SC2570A, but the latter would be better due to lower noise.
The best of the best preamps use the Agilent ATF10136 gas-fet or similar.
you could google for that and find all kinds of incredible LNA designs.
__________________
"Y'all mind hanging back? You're jamming my frequencies" -- Tangina in Poltergeist
Reply
Bookmarks
Tags
440mhz preamp, 70cm preamp, ramsey kit, ramsey pr40
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/home-brew-mods/35101-ramsey-pr40-440mhz-preamp-kit.html
Posted By For Type Date Hits
[amsat-bb] Re: Arrow 10W Duplexer Performance Measurements This thread Refback 10-23-2009 08:53 PM 3
VX-8r mod | Addictomatic This thread Refback 08-24-2009 03:12 PM 4
Powered by vBulletin®
