I finally located the remaining parts and had time to assemble the amp. Believe it or not, I couldn't find BNC bulkhead connector anywhere until I went to the electronics swap meet.
First, here is the schematic of the Ramsey preamp:
Here are all of the parts laid with the batteries & board sitting in the box to determine fit. this project box had the mounting posts right in the middle of the box, so I had to use a dremel tool to cut them off to make enough room for everything.
First up, drill the holes and mount the BNC connectors and switch:
Ramsey PR40 Kit assembled:
Everything installed in box and ready to go:
The batteries are hookup up in serial to produce 18V at full charge. Parts of the manual say the kit is "rated" for up to 16v, the schematic says 15v. You can see in the above picture some 1/2 watt resistors inline on the power feed. This was an attempt at making a simple voltage divider to drop the 18v down a little. That didn't end up working out so I removed it. I'm not really all the concerned about 2 volts more...as the batteries weaken the voltage will drop anyway.
I was also going to use the small coax in the original picture for the RF leads, but the coax was too stiff and as you can see the RF leads are barely an inch long anyway.
Here is the box all buttoned up:
Keep in mind that with the preamp in this configuration you
cannot transmist on 440Mhz while the amp is inline. If you want to do that you need to rig up a
RX bypass. You could do it with a RF sensing transistor and relay or some other method. Ramsey even has another little kit you could purchase (RFS-1) to do this. I'm not concerned with this issue since I'm using a duplexer on the antenna to
RX only 440mhz and
TX on 2m.
And finally, here is the preamp attached to the Arrow 2m/440 antenna:
The only extra cable with BNC ends I had laying around was longer than necessary, so I wrapped the excess around the handles until I can pick up a shorter one.
Initial test results were fantastic! I pointed the Yagi south toward a repeater that is over some hills, about an hour drive away from me. With my
HT attached and the 7 element yagi, it was just breaking the squelch and the conversation was barely intelligable. When I flipped on the preamp, it brought the signal up to an S5, 100% perfect copy, barely any noticeable noise on the
HT. I then put the preamp inline with a little 1/4 wave 440 magmount that I have in the house on a piece of steel and found another active repeater. I turned on the attenuator on the
HT to drop the signal to an S5. When I flipped on the preamp, the signal came up to S9.
Total cost for the kit and all parts (not including batteries): about $35.
Next up, testing out on some satellites.
