Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > Home Brew & Mods
Amateur Callsign Lookup
Enter Callsign:
Homebrew 1.2 Ghz 10 element yagi antenna
Reply
LinkBack (7) Thread Tools Display Modes
  #11
Old 09-02-2009, 09:09 AM
Junior Member
kd0fqx is on a distinguished road
Default
Quote:
Originally Posted by moleculo View Post
If you don't already have a 440 yagi (like I did), you might build it this way (only for 1.2/440) like she did:
If my local club had members like this, I would join.
Do the orange caps on the elements do anything, or are they just there for eye protection?
Worldwide Radio Forum
  #12
Old 09-02-2009, 10:52 AM
Senior Member
moleculo has disabled reputation
Default
They're foam earplugs stuck on there for eye protection only.
  #13
Old 09-02-2009, 11:15 AM
Senior Member
linearone is an unknown quantity at this point
Default
I've been wanting a 1.2Ghz yagi so I could try to work the AO-51 satellite on 1.2 with my Alinco DJ-G7. After looking around at commercially available antennas, I decided to build one myself with some of the plans that are available online.
The design and specs are from WA5VJB. He says the measured gain is 13.5dbi. I followed his plans for the 1.2Ghz antenna almost precisely. The antenna elements are 1/8" steel rod and were measured using digital calipers. I wanted to use bronze or some other material that wouldn't rust, but Home Depot was out of the bronze rod on the day I happened to go there. The boom is a a 3/4" square wood piece, a little less than 4' long. I cut off a little of the excess. The elements are within a few 10,000's of an inch of the specs! I also carefully centered them on the boom from side to side and top to bottom so that they're all properly aligned
Here is the finished antenna:
The driven element is 12ga house copper ground wire. (WA5VJB used 10ga wire, but it shouldn't make any difference). I had some excess on the shelf in the garage, so I put it to use. I also had some RG8x that already had one PL-259 on it, so I just used that for the connection to the driven element. You can also see that all of the elements are epoxied into place.
You could move the driven element up on the boom and drill two holes, but it just happened to work out that the center of the square wood allowed for the driven element to be exactly 1/2" in diameter with the bottom of the element epoxied to the boom. I plan on covering the coax connection with RTV silicone, but I wanted to leave it bare for the picture.
And finally, here is the intended use for the 1.2Ghz yagi. The square wooden boom lays nicely on top of the 440Mhz Arrow boom and I just velcro'd them together. This is starting to get a bit heavy for handheld use, but I'll give it a try and see what happens.
I don't have an SWR meter for 1.2 Ghz yet, so I don't know what the bandwidth of the antenna is. A quick test however confirmed that the antenna indeed has some good gain! I was able to hit a repeater with my 1 watt HT that is about 37 miles away that I could never hear or hit before .
I've attached the design specs, which also includes plans for 2m, 220, 440, and 900 Mhz. If you plan on mounting this outside, you could easily attach a u-bolt. You would also want to weatherproof the boom and elements using some paint, marine varnish, or similar. Total cost for the antenna (not including coax & PL-259) was exactly $10. Half of that cost was for the epoxy.
this is real radio at its best.
very cool.
I love cheap homebrew projects like this.
__________________
Bomb Diggity!
_____________________________________
Quote Bob85: "peoples' personal non factual opinions mean nothing to me period, BS is 10 cents a gallon anywhere you look for it"
  #14
Old 09-02-2009, 05:34 PM
Senior Member
Default
man, everything is better in cali, the surf, the antennas, the ham operators (they dont look like that here)
__________________
Bomb Diggity!
  #15
Old 09-02-2009, 09:09 PM
C2's Avatar
C2 C2 is offline
Senior Member
C2 is on a distinguished road
Default
Well, I'm not sold yet. She seems like a front...is that not a black nightie???
But the designer did make a comment on her blog...
Make: Online : Catching satellites on ham radio
  #16
Old 09-12-2009, 09:54 AM
Junior Member
n2gbt is on a distinguished road
Default 23cm spacing
Can you clarify the spacing on the 1.2 gig elements-
Not sure why but it seems confusing to me-
you start with the reflector and then space each element forward by the distance in the chart?
Joe N2GBT
  #17
Old 09-12-2009, 11:34 AM
C2's Avatar
C2 C2 is offline
Senior Member
Default
the measurements are all from the back end of the boom.
The front element, D7, is 23 inches from the back end. D1 is 4 inches from the back end, etc.
  #18
Old 09-13-2009, 09:36 AM
Junior Member
Default 2cm antenna
thanks- figured it was that simple. Just finished making the antenna- all the elements are within .01mm accuracy- for the driven element-
what is the total length of the driven element-
I see 1.75 + .5 + 1.75 on one set of plans but it appears that the driven element is one continous piece of copper- with one end epoxied in place( I will probably drill a hole and slide this end into the pvc boom)
and wrapped around the boom with 1/2 ich spacing
do you know the total length of copper wire needed/
Thanks
Joe
( just put the 1.2g module in my ts790 cant wait to try this)
  #19
Old 09-13-2009, 09:44 AM
Junior Member
Default 2cm antenna
I am showing a distance fromt he reflector to the last element (D8) of 23 inches I HOPE this is correct
Thanks
Joe
  #20
Old 09-13-2009, 09:48 AM
Junior Member
Default 10 el yagi specs- corrrect?
1296 MHz. This antenna is the veteran of several "Grid Peditions" but I have yet to actually measure the gain. Dimensions must be followed with great care. The driven element is small enough to allow 0.141 semi-rigid coax to be used instead of RG-58. Silicon Bronze welding rod was used for the elements but any material can be used. Driven element dimensions are L = 4.0" and H = 1/2" Elements are 1/8" diameter.
1296 MHz Reflector Driven Dir 1 Dir 2 Dir 3 Dir 4 Dir 5 Dir 6 Dir 7 Dir 8
10 Element Length 4.30 3.90 3.80 3.75 3.75 3.65 3.60 3.60 3.50
10 Element Spacing 0.00 1.70 2.80 4.00 6.40 8.70 12.20 15.60 19.30 23.00
Reply
Bookmarks
Tags
1.2ghz, 1.2ghz yagi, 23cm yagi, homebrew yagi
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/home-brew-mods/35899-homebrew-1-2-ghz-10-element-yagi-antenna.html
Posted By For Type Date Hits
Posts Recenti This thread Refback 10-07-2009 12:19 PM 1
Radio-Amatori.it - Radioamatori - CB - Apparati e antenne - modifiche e autocostruzione • Leggi argomento - Curiosità This thread Refback 10-05-2009 02:25 AM 1
Radio-Amatori.it - Radioamatori - CB - Apparati e antenne - modifiche e autocostruzione • Leggi argomento - Curiosità This thread Refback 10-04-2009 03:51 PM 1
Radio-Amatori.it - Radioamatori - CB - Apparati e antenne - modifiche e autocostruzione • Leggi argomento - Curiosità This thread Refback 10-04-2009 12:57 AM 8
Curiosità This thread Refback 10-04-2009 12:50 AM 2
Curiosità This thread Refback 10-04-2009 12:38 AM 4
Curiosità This thread Refback 10-03-2009 11:31 PM 1
Powered by vBulletin®
