Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > Home Brew & Mods
Amateur Callsign Lookup
Enter Callsign:
HF homebrew tube amp photo build
Reply
  #21
Old 10-02-2009, 01:17 PM
Senior Member
linearone is an unknown quantity at this point
Default
looking real good! but you will only be able to see the glow from the top
__________________
Bomb Diggity!
_____________________________________
Quote Bob85: "peoples' personal non factual opinions mean nothing to me period, BS is 10 cents a gallon anywhere you look for it"
Worldwide Radio Forum
  #22
Old 10-02-2009, 01:29 PM
Radio Tech's Avatar
Radio Operator
Radio Tech is on a distinguished road
Default
Quote:
Got to do something about that!
The top opens like a door. I am going to cut the part out over the tubes and put mesh over it. Get that heat out and watch the glow.
  #23
Old 10-02-2009, 03:04 PM
Captain Kilowatt's Avatar
Administrator
Captain Kilowatt is on a distinguished road
Default
Looks like you are off to a good start. I am working nights tonight and tomorrow night with Sunday off (sleep day) and then back to work on Monday and Tuesday which is off my normal shift rotation but it enabled me to get nine days off in a row so I hope to get a few things started myself. I need to get some things done around the yard and put up an antenna but hopefully I can get some chassis work done. I have an old cabinet that was originally a frequency meter I think. It's about 17w X 9½h X 12d and needs a couple holes filled,sanded and a fresh coat of paint. The front panel has rack handles and will actually bolt to the homemade chassis allowing the entire innerds to be slid out for ease of service. I'll get some pix up early next week after I get a chance to tell night from day. On a side note,I just found out my planned 2000pf loading capacitor is about ½ inch too long to fit. Time to hit the junque box. I prefer to spell it "junque" and not "junk" because it is a higher class of junk.
__________________
Front/back ratio comes from the antenna. Forward gain comes from the wall socket.
  #24
Old 10-02-2009, 04:13 PM
Radio Tech's Avatar
Radio Operator
Default
Hey I love junque!
Know what you mean about the night shift. Did that for 4 years. Been back on days for a little over 2 years now.
Cant wait to see you get started on yours. But I know how times is.
Paint
Going to paint the chassis with Walmart special. The paint is made by Rustoleum. It is called "Hammered" and leaves a great looking finish. They have it in many colors.
You you paint the inside of the tube compartment, (and I suggest you do) paint it with a flat color. This will keep the filaments from reflecting off the tube compartment and creating more heat. With 3-500's this is a must.
Transformer.
I am going through transformers to see what I can use. I have to look closer and see what the 811A and 572B likes. One transformer I have came from a Pride DX300. I believe this is 2000 volts after filter and rectifying.
  #25
Old 10-02-2009, 06:14 PM
Senior Member
Default
Quote:
why not just un do it and shorten it? it can be done kinda easy if you are careful. it takes loads of time though
__________________
Bomb Diggity!
  #26
Old 10-03-2009, 07:17 AM
Administrator
Default
I thought of that but this one is a tough one. It has ceramic insulators running the length of it.It's actually two 1000pF caps laid end to end on a common frame.It would involve cutting two pieces of ceramic as well as three brass rods that run the length of it. I'll post some pix in a couple days,after the night shifts end and you will see what I mean.
__________________
  #27
Old 10-03-2009, 07:24 AM
Administrator
Default
Quote:
Originally Posted by Radio Tech View Post
Paint
GREAT! Now you are going to make me look like a copycat! I must state that I have already painted the large 42 inch cabinet for the 3-500 amp with Walmart Hammertone black and will be doing the same on the 572B cabinet. BTW, a good paint for the inside is also available from Wally Mart.I used, and will be again, their "textured" black paint for outdoor metal furniture. It is flat black with a somewhat rough finish which is rougher than just a flat paint but not pebbled like that rocky texture stuff. I figure my amp will be hammertone black on the outside,textured flat black on the inside and the front panel will probably be gray hammertone or another shade of gray.I have a couple to choose from.
__________________
  #28
Old 10-03-2009, 08:57 AM
Radio Tech's Avatar
Radio Operator
Default
Well you know what they say, great minds think alike
I love those Wal-Mart paints. Great for covering lousy prep work like grind marks and so on. Plus gives the finish character!
  #29
Old 10-03-2009, 02:39 PM
Administrator
Default
That's exactlythe reason I chose the hammertone paint, to hide all the little imperfections.
__________________
  #30
Old 10-03-2009, 03:14 PM
Radio Tech's Avatar
Radio Operator
Default
That stuff works wonders and goes on al my restorations
Ok, The circuit.
If anyone wants to see a what this amplifier circuit looks like, this one will be close as you can get.
http://jlandrigan.com/files/DX-811A%...0Amplifier.pdf
This was in CQ Magazine September 1982.
Although it will differ to some extent.
I been going through transformers today.
Not having much luck. One transfomer I have came out of a Pride DX300. By the time this is rectified and filtered it will be around 2400 volts. Now that may be a proble for the 811A tubes! But this is with no load.
The 811A as I have read likes about 15 to 17 hundred volts. The transfomer under load should drop to 1800 volts @ 500ma (If I done my math right).117VAC @ 10 amps gives 1800VAC out.
Two disavantages are no CT on the secondary and no 240 input on primary.
So with 120VAC in, voltage drop across the supply, and the ground of the bridge recitifier on the TX relay, no voltage present in the stand-by mode.
I have to think about this more.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
homebrew astroplane build loosecannon CB Antennas 5 07-11-2009 05:16 PM
homebrew 811A amplifier project loosecannon Amplifiers 3 07-10-2009 09:21 PM
Smallest tube amp available quiksilver Amplifiers 6 06-27-2009 12:13 PM
Tube Amp adjustment. 190 Amplifiers 11 03-14-2009 07:54 AM
Coil Loaded Dipole build - photo diary moleculo Amateur Radio Antennas 41 11-18-2008 07:54 PM
Powered by vBulletin®
