Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > Home Brew & Mods
Amateur Callsign Lookup
Enter Callsign:
Homebrew 572B amp
Reply
  #1
Old 10-04-2009, 05:42 AM
Captain Kilowatt's Avatar
Amateur Professional
Captain Kilowatt is on a distinguished road
Default Homebrew 572B amp
Well I just got off work this morning and thought I would start this thread before catching a nap.As discussed in the other thread,I plan to build a 4 tube 572B amp I have a cabinet that needs some paint and the first decent day I get next week it shall receive that paint.Black hammertone on the outside and a flat textured black on the inside. The front panel will be either hammertone gray or just regular gray.Here is the cabinet.Note the 12 inch ruler for scale.
Here is the loading cap I was going to use. It is 2000 pF but is too long and quite hard to modify. It has ceramic insulators holding it together and that makes it pretty hard to shorten. I have some other caps suitable for loading caps in an amp this size so it's time to find out where I stashed all my goodies.
Updates in a few days after I have a chance to get to it. I work Monday and Tuesday and then off for nine days,back for two more and off another six so I hope to get a decent start on this project.
__________________
Light travels faster than the speed of sound, this is why some people tend to appear bright, until they decide to speak.
Worldwide Radio Forum
  #2
Old 10-04-2009, 07:48 AM
Radio Tech's Avatar
Radio Operator
Radio Tech is on a distinguished road
Default
Thats a nice looking cabinet! It should work out fine.
One question. How much room is under the chassis? Or is it flat bottom and up?
Reason I ask is it possible to use that capacitor under the chassis (Legnth ways) and turn it with some sort of manual drive?
This is going to be fun with two homebrew amp threads.
  #3
Old 10-04-2009, 09:15 AM
Default
I forgot to mention that the cabinet is empty,there is no chassis. I will make one from some aluminum panels I have. It will be bolted to the front panel and the entire chassis will be able to be slid out the front leaving the empty cabinet behind. The panel that you see that is gray in colour and has the rack handles is grooved and mates perfectly with the cabinet. It is just sitting there in the picture and is not fixed to the rest of the cabinet. A simple raised chassis and a couple tiedown bolts should do the job. As for under chassis mounting of the cap, I don't have the room ( I don't think) but I will look further into that. I had thought the same thing when I found my right-angle reduction drive seen here.
The potential new loading capacitor if the big one does not fit. It needs a little cleaning but no big deal.
The plate tuning capacitor,a Cardwell T-199.
Possible Pi network inductor. It was the coil for the second harmonic trap in an RCA 1 Kw AM broadcast transmitter.
One of several ceramic RF switches I have. In this configuration it will serve as both input and output network switches.The single section will select the tap on the final tank coil while the dual section will select the appropriate tuned input for each band.The dual section input section will be housed in a shielded enclosure.
And last but not least for now, the plate tranny. The primary is either 208 or 240 volts and you can select +/- 11 volts from that. Normaly primary connects to the 0 and 240 terminals. The secondary is either 930 or 1150 volts with Hi/Lo taps for +/- a bit. With the 1150 and Hi taps used the power supply will deliver 2000 volts using a 100 uF filter capacitor rated at 2500 volts.
This is starting to become fun.
__________________
  #4
Old 10-05-2009, 03:26 AM
Radio Tech's Avatar
Radio Operator
Default
And fun it will be.
Any particular schematic you going to work off of?
I been looking at the Dentron Clipperton with the 4 572B's
BTW, I would kill for that transformer. Was going to Maysville hamfest next week to find me one but dont think I am going to be able now.
  #5
Old 10-05-2009, 06:48 PM
Default
Not following any one particular design really. The basic amp portion is really pretty simply. It's making all the switching and control systems work that is the challange. Things like step-start timing for the plate supply and inrush protection for the filamants and some type of ALC as well as designing the tuned input is what is going to be the head scratching part.
As for the transformer,I hope it will be heavy enough.I have no idea what kind of current it is rated for. It is a Kenyon transformer and finding data on it is next to impossible. It was originally the 4-400 screen supply transformer in the old RCA b'cast TX. I'll have to take a pic of the plate tranny for the BIG amp I want to build later. If you like the one above, all I can say about the other one is . Here's a hint:it weighs 85 pounds.
__________________
  #6
Old 10-05-2009, 07:10 PM
Radio Tech's Avatar
Radio Operator
Default
I hear that.
I been looking at the AL-572 and the Collins: 30L-1 for ideas with mine.
Man that is a heavy duty transformer. I hope it has wheels!
  #7
Old 10-05-2009, 07:22 PM
Default
Quote:
No, but the 42 inch high Hammond rack cabinet it will be in does.
You should have seen me carry it up the basement steps and then decide I was going to put that project on hold and then carry it back down the basement steps.
It was the plate transformer for,you guessed, the RCA 1Kw broadcast tx I scrapped after it had a modulator meltdown. It creamed everything from the mod tranny back thru the 4-400 modulator tubes and took out one of two 2E26 audio pre-drivers. It powered a pair of 4-400's in class C plate modulated RF service to make 1 Kw carrier (CCS) with 100% modulation that came from another pair of 4-400's in class B modulator service so it should settle in quite nicely as an amateur amp being operated ICAS.
__________________
  #8
Old 10-08-2009, 09:07 AM
Default
No more progress in the last couple days except for looking for and finding some more parts. I need to build a chassis and plan a layout of the components. It's going to be a tight fit but I think it will all come together.I think I will lay it all out on bristle board first and mark holes etc. that way I can simple use it as a template to drill and blast the holes. Looks like a lot of wet weather the next week so I may be able to get something done. I managed to hurt my hand at work the other day and it makes for holding things and fine movements of the right thumb a bit difficult and a lot painfull. I was asked to hold a wrench on a nut that was spinning as another guy tightened the bolt from below the machine.Unknownst to me just as I reached for it another guy in maintenance thought he would be smart and put his air impact driver on the bolt head. The wrench made a 270º turn in a flash before coming to a stop at the base of my right thumb between the thumb and index finger,bruising a tendon in the process. I don't actually recall having anything hurt so damned bad in my life and that includes the time I crushed a finger in between two rollers. The swelling has caused my thumb to want to lock up a bit when bending it at the middle joint and it really hurts. Hopefully in another couple days it won't be as bad and I can actually do some things I want to since I just started a break from work of nine days off. I go back for just two days and then I am off for another six days so I had better be able to take advantage of the down time to work on this project. It happens to be my right hand too and I am right handed as well. It figures.Anyway in the meantime I am still gathering bits and pieces and the more I find the better I feel about it. I think I have everything now except the actual tubes and a filamant transformer.I was sure I had a xmfr but cannot seem to locate it.I do have a xmfr that I may try my hand at rewinding the secondary of to get whet I need. I have done that a couple times in the past but if my hand takes too long to feel better I just may say WTF and buy one.
__________________
  #9
Old 10-08-2009, 09:24 AM
Radio Tech's Avatar
Radio Operator
Default
Hate to hear about your hand incident. Hope it heals soon.
Pain stops everything!
Sort of at a stand still on mine also at the moment. Its gathering time. I will update that thread shorly.
Your template idea sounds like the way to go. Noo need to drill holes only to find it should had been another way. I have wind a few transformers also but you need three hands to do it right
Take care and rest that hand!
  #10
Old 10-15-2009, 11:42 AM
Default
Not much of an update but not much has been done lately. I have been tearing the shack apart in preparation of a complete rebuild from the ceiling to the floor so the amp project has been put aside for a short bit. If you remember, the cabinet I was going to use was in dire need of a little TLC and some paint.Well here it is after getting what it needed. The cabinet is painted "textured" black on the inside and Hammertone black on the outside. The front panel is hammertone gray and the escutcheon/bezel around the front panel is painted with a textured grey. The textured paint is not quite flat but not quite gloss finish,more like a satin finish, and feels slightly rough to the touch.It gives what I think is a nice grainy look. I think the colour scheme worked out well.
__________________
Reply
Bookmarks
Tags
homebrew 572b amplifier
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/home-brew-mods/36423-homebrew-572b-amp.html
Posted By For Type Date Hits
Home brew 572b This thread Refback 01-17-2010 01:26 PM 1
Similar Threads
HF homebrew tube amp photo build Radio Tech Home Brew & Mods 40 03-30-2010 06:32 PM
homebrew 811A amplifier project loosecannon Amplifiers 3 07-10-2009 08:21 PM
Need Help Setting Up Radio Neuro CB Band and CB Radios 24 06-10-2009 01:30 PM
high swr when amp on. flat swr when amp off iceman78 Amplifiers 8 02-16-2009 09:34 AM
Coax for Mobile Installation with Amp this_is_nascar Installation & Station Setup 7 02-14-2009 05:20 AM
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.1
