Quote:
Originally Posted by Tube Doctor Anybody???????? GU50 build info Specs ect? |
It's a vacuum tube, treat it like one
Class C (telegraph mode)
Ua= 1000 V (max. 46,1 MHz)
Ua= 800 V Imax. 66,6 MHz)
Ua= 700 V (max. 85,7 MHz)
Ua= 600 V (max. 120 MHz)
Ia = 120 mA
Ug2 = 300 V
Ig2 = 10 mA
Ug1=- 80 V
Ig1=0 mA
Pout=85 W
max cathode current: 230 mA
heater: 12,6 V/0,7A
You are not going to find any "How to / DIY" instructions for that tube, your best bet is to adapt an existing design to fit your application. X-Force or Charger have never built one of these so, the appliance-operating world has nothing to copy from.
The tube looks interesting with that metal heat dissapation cap on the top. If you are interested in working with that tube, but 4-6 of them and some sockets and get busy.
Are you trying to build a high Mu Grid-driven amp (like the 4CX-250b style), if so then your tuned input circuit is critical along with the stability of the screen and bias supplies. You could ground all grids, feed the cathode like they do with the 6LQ6 tube and hope for the best. I would not consider using the exact circuit as the 6146 because of the way that tube is internally constructed.
