03-13-2012, 01:16 PM
| W9WDX Amateur Radio Club Member | | Join Date: Jun 2009
Quote:
Originally Posted by Captain Kilowatt I have no problem with injecting a DC control voltage on my coax cable if it is done proberly with the right blocking capacitor on each end and the series coil for the DC to flow thru while preventing RF from getting back into the power source. The only issue is that you are very limited in the number of relays you can switch this way. Typically you are limited to three antennas with one being on when the power is off, one operates from a pos. voltage and the other from a neg. voltage. | If the blocking cap fails what would the result be to the transceiver?
I just prefer not to take the risk of adding a potential problem that would result in catastrophic damage to a transceiver or associated equipment. One less thing to worry about.
Other ops do run the control voltage on the coax. |
