Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Home Brew
Amateur Callsign Lookup
Enter Callsign:
What to do with bent up junked working DX-40?
Reply
  #1
Old 11-05-2012, 07:20 AM
T23 T23 is offline
Senior Member
T23 is on a distinguished road
Default What to do with bent up junked working DX-40?
I got another DX-40 in, damaged in shipping, it works but the case and the chassis is bent along the middle as if the weight of the transformer and the chokes weight bent it in rough shipping. The tank coil has been damaged but still works aswell.
Any Ideas?
I was thinking of building another transmitter with the parts, It has 2 6cl6, a 6de7 modulator, a 12by7a and a 5u4gb rectifier tube I believe.
I was thinking a vfo could be built with on of the 6cl6 tubes and the final could be reworked.
T23
  #2
Old 11-05-2012, 10:27 AM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
Return it to stock condition, it'd be worth more. Wanna VFO? Build one, but don't 'rob' the DX-40 to do so, no point in that. Just wanna tinker around, see what happens? It's yours, do whatever...
  #3
Old 11-06-2012, 05:41 AM
doctor's Avatar
doctor is on a distinguished road
Default DX40
I don't know if you should rebuild all of it since it does work, just straightened it out as best as you can..I would also be after the shipper, I always raise the devil with UPS, they now put my packages down instead of tossing them..down on the vehicle hood and one time in the drive.
See you on 75 am maybe..
DOCTOR
__________________
73/DOCTOR...K8LEN
DAV Life time member
  #4
Old 11-06-2012, 06:14 AM
T23 T23 is offline
Senior Member
Default
I might consider trading or selling it, but the shipping weight I would rather not bother with, I ahve a nice working dx-40, still trying to figure out the the modification on that one with a TX swithching relay, it has a 4-pin mic plug where the key jack should be, and the key jack has been moved to the back.
It modulates well with the MC-60 mic I have set to 50k ohm impedance.
What I cant figure out is it does not seem that the relay is switching, but it transmits fine AM when switched to the "Phone" setting. But it is supossed to be swithced with the added TX relay from the mic pins.
I would be intrested in a receiver and dow-key switch to go with my good dx-40 if anyone has one for a good price.
T23
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
*Wanted* GE Super Base or MIDLAND 78-999 working or non working bojangles CB Radio Gear SwapShop 0 07-13-2012 08:40 PM
trying to find a working ms dos 6.22 rob General CB Services Discussion 7 06-21-2011 06:41 PM
Package deal for a good working HF Tranciever kd6rhr CB Radio Gear SwapShop 0 01-08-2011 02:50 PM
527 Cali. Working his Mobile!!! 15minigrass DX Contacts 0 05-14-2010 07:14 PM
Lafayette KT320 2 bands not working PLAFETTE General CB Services Discussion 9 03-13-2009 09:19 AM
Powered by vBulletin®
