Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Home Brew
Amateur Callsign Lookup
Enter Callsign:
uniden grant xl 10 meter mod
Reply
  #1
Old 11-17-2009, 07:25 AM
KD0GOJ is on a distinguished road
Default uniden grant xl 10 meter mod
Has any one done this mod on there grant
10 Meter Conversion
***For Licensed Amateur Radio Operators Only*** This very easy conversion of your XL will give you a back up SSB 10 meter radio. Find crystal "X3" which is a 11.325 MHz Change crystal "X3" to a 11.6908 MHzThis will give you 28.060 MHz to 28.500 MHz
Just found it and have been wanting a 10 meter radio for my jeep
and since i can't afford one just now
Thanks
KD0GOJ
  #2
Old 11-17-2009, 03:45 PM
Moleculo has disabled reputation
Default
There was some discussion here a long time ago about doing this on a Cobra 148GTL (same radio). I remember some saying that it works quite well!
  #3
Old 11-17-2009, 04:02 PM
Sonwatcher's Avatar
Senior Member
Sonwatcher is on a distinguished road
Default
Quote:
Frequency conversions by crystal changes
This mod came from a forum I am a moderator on:
(You need to change the crystal at location X3)
Quote
" 11.6908MHz gives 28.060MHz to 28.500Mhz (Ham 10 Meter) operation in Cobra/Uniden CB's that originally had 11.3258MHz in them "
You really just need 28.300 to 28.500 for voice, the lower part of the band is CW.
You can use a 11.4758MHz to get the high band, or a 11.1758MHz to get the low band instead if that is what you need.
You can get new crystals from Kens Electronics:
CB & Amateur Ham Radio crystal frequency list at Ken's Electronics, (Wholesale & Retail Electronic Parts) Kalamazoo, Michigan
I believe this is one.
__________________
http://www.haminfobar.co.uk
CDX-897
OT-897
WR-1897
AK-1897
RT-897
  #4
Old 11-17-2009, 04:23 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
Q: When this mod is done; isn't it also necessary to 'broadband' the TX - or else a loss of power due to filtering restrictions still present?
__________________
BASE: Kenwood TS-2000, GAP Titan DX, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
  #5
Old 11-17-2009, 04:43 PM
Default
Thanks for the info guys
I will be talking to the local tech and see what it cost.
I think it is a little over my level of skill.
I will see if santa will have it done for me.
Thanks again
KD0GOJ
  #6
Old 11-17-2009, 05:20 PM
Default
Quote:
You will probably have to broadband the bandpass filter otherwise you can get some power drop off. There is a discussion about that mod in this thread:
http://www.worldwidedx.com/radio-rad...rant-mods.html
  #7
Old 11-17-2009, 08:07 PM
loosecannon's Avatar
break on through
loosecannon is on a distinguished road
Default
if you just change the crystal; you will just have to re-align the radio for that freq range.
you wont have to broadband it.
if you want to keep the CB band and be able to switch back and forth between 10 and 11 meters; you will have to broadband the radio, but you will still experience a power drop at the band edges.
best bet is just to change the crystal and have the radio realigned for the new freq range.
good luck, and make sure you get a crystal with the right characteristics. otherwise the SSB will suffer.
__________________
https://i.chzbgr.com/maxW500/1912864512/h0491035C/
  #8
Old 11-21-2009, 02:07 PM
jazzsinger's Avatar
Bullshit Buster
jazzsinger is on a distinguished road
Default
Quote:
I wouldn't have thought the drop off at band edges would be too severe as its only 1.5 mhz bandwidth,a realignment would probably suffice although I am not familiar with that chassis and slight broadbanding may be necessary to vco or tx mixer.
Couldn't agree more for optimum performance.
Very good advice,the wrong load capacitance on the new crystal could have dire effects on clarifier circuit swing.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/home-brew/37151-uniden-grant-xl-10-meter-mod.html
Posted By For Type Date Hits
11meter to 10 meter conversion - Page 3 - QRZ Forums This thread Refback 01-13-2010 08:10 PM 2
11meter to 10 meter conversion - Page 3 - QRZ Forums This thread Refback 01-13-2010 03:35 AM 24
uniden grant xl 10 meter mod This thread Refback 11-18-2009 08:09 AM 1
Similar Threads
THE UNIDEN GRANT XL OWNERS CLUB ? Switch Kit CB Band and CB Radios 23 05-11-2010 04:26 PM
Clipperton 10 Meter Mod Questions Cajun Invader Amplifiers 13 05-16-2009 05:54 AM
Grant XL Meter Problem ? Switch Kit General CB Services Discussion 1 05-04-2008 02:29 PM
Uniden Grant XL best ever who else thinks so radioreddz CB Band and CB Radios 33 03-13-2007 08:49 AM
mb8719 pll 10k (able's) switch - uniden grant/ cobra 148 Carl General CB Services Discussion 3 06-25-2006 10:14 AM
Powered by vBulletin®
