Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Home Brew
Amateur Callsign Lookup
Enter Callsign:
best way to bend solid aluminum rod and sheet ???
Like Tree1Likes
Reply
  #9
Old 05-07-2010, 08:25 AM
swanny is on a distinguished road
Default
KEY to METALS Articles: Heat Treatable Aluminum Alloys
depending on the size and configuration, I don't know that i would mess with trying to harden the sheet after it has been bent. Depends on what you're gonna use it for. As the article says, you can heat treat and quench some aluminum. Annealing will make it easier to work with but if you're talking about solid stock round aluminum, it's not gonna be just butter. Bending it round for something like a gamma match, it will hold it's shape just fine after forming. Also, the more temper you put into a piece of metal, the more brittle it becomes.
  #10
Old 05-07-2010, 02:29 PM
packrat's Avatar
Senior Member
packrat is on a distinguished road
Default
I personally never worry about annealing any aluminum I work with. Anything that you will use for building an antenna will be easy enough to form as is. You don't think the antenna manufacturers anneal, do you?
__________________
Incentives are important.....I learned that in rehab!
  #11
Old 05-07-2010, 02:46 PM
BOOTY MONSTER
Guest
Posts: n/a
Default
Quote:
ill be bending either 1/4 inch 5/16 or maybe even 3/8 inch diameter solid aluminum rod . heres the specs for it .
6061-T6 and 6061-T651
ALUMINUM ROUND
Federal Spec QQ-A-225/8 Cold Finished
Federal Spec QQ-A-200/8 Extruded
12 Ft. Length
i havnt seen any cb antenna builders use solid aluminum rod of that thickness and i have no idea how antenna manufacturers build their products . usually aluminum tubing and cast hubs and SS brackets are used .
ill have some 3 foot scrap peices to pratice with using the suggestions here so far .
thanks folks
  #12
Old 05-07-2010, 03:19 PM
Default
You might have to use more heat than just annealing if you plan on making sharp bends with the thicker solid rods bootymonster.
  #13
Old 05-07-2010, 04:07 PM
Senior Member
Shockwave will become famous soon enough
Default
I've had great luck just using a propane torch. I've heard the carbon of acetylene only works better but propane works fine. It should be fairly hard to melt the material with just propane if it's at least 1/4 inch. You don't have to bring the temperature too close to the melting point to soften it either.
binrat likes this.
  #14
Old 05-07-2010, 04:35 PM
packrat's Avatar
Senior Member
Default
Try it cold first. Sizes that small shouldn't be a problem. I used to build fire and rescue vehicles from scratch, most were aluminum bodies, and i don't think I ever needed heat except to weld em together. Aluminum is pretty soft, and unless you are bending complex shapes or heavy stock, it should bend fine. The idea of using a pulley, or other round form for shaping round or square stock is a good one, too. A break or brake press will make flat work easy, but clamping angle to a work bench works, too. I wouldn't beat on it though, as it leaves unsightly damage and causes stress points.
__________________
  #15
Old 05-07-2010, 07:51 PM
Jock Supporter
mackmobile43 is on a distinguished road
Default
Tubing 3/8'' and lower is easy enough to just fill with sand and bend.
  #16
Old 06-16-2010, 01:45 AM
KI7FOX's Avatar
Junior Member
KI7FOX is on a distinguished road
Default
Quote:
Originally Posted by mackmobile43 View Post
Yep I learned about the annealing process watching Jesse James making fuel tanks for custom bikes.
Wow! I was totally thinking of the same thing. I miss that show.
__________________
Equipment:
Base: Yaesu VX-6R, Mirage dual-band amplifier, and an external dual-band antenna on the roof
Mobile/Portable: Yaesu VX-7R, Diamond 2m/70cm Antenna, and mag mount 2m/70cm antenna. Homebrew dual-band Yagi for working satellites.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
buying aluminum again BOOTY MONSTER Home Brew 5 06-06-2010 01:26 PM
Powered by vBulletin®
