Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Home Brew
Amateur Callsign Lookup
Enter Callsign:
corrosion/oxidation between aluminum and galvanized steel ?
Reply
  #1
Old 01-27-2011, 09:16 AM
BOOTY MONSTER
Guest
Posts: n/a
Default corrosion/oxidation between aluminum and galvanized steel ?
i know copper and aluminum will have issues when touching each other . but what about aluminum and galvanized steel/conduit/mast ? will one eat at the other or cause corrosion ?
thanks .
  #2
Old 01-27-2011, 09:44 AM
359's Avatar
359 359 is online now
Senior Member
359 is on a distinguished road
Default
A lot of dissimilar metals can cause corrosion, and zinc chromate is generally the cure. But since galvanized steel is zinc plated, I don't know really, lol, did that help?
__________________
From milliwatts to kilowatts its all cool to me .... but life is to short for QRP !!
  #3
Old 01-27-2011, 10:06 AM
itx itx is offline
Junior Member
itx is on a distinguished road
Default
The zinc will corrode into a white powder over time. It will protect the steel as it does this but you really should isolate the aluminum and steel with some sort of insulator.
Galvanic corrosion - Wikipedia, the free encyclopedia
  #4
Old 01-27-2011, 05:05 PM
NY739 Mobile's Avatar
Junior Member
NY739 Mobile is on a distinguished road
Default
Ive found in my own experences that there is not much effect with the two in contact but it depends on different factors, hardware , location, etc.....here is a link that might be usefull...
Dissimilar Metals in Contact with Hot-Dip Galvanized Steel
Quote:
thanks .
__________________
RCI 2970N2
108" stainless whip
  #5
Old 01-27-2011, 09:19 PM
Senior Member
Shockwave will become famous soon enough
Default
thanks .
If you are joining these two metals together to make a permanent RF connection you might consider soldering them together. Muggy Weld makes a special 350 degree low temperature solder called Super Alloy 1. It will cleanly join almost any types of metal together that you can think of. What was once impossible to solder, is now easy.
  #6
Old 01-28-2011, 08:19 AM
BOOTY MONSTER
Guest
Posts: n/a
Default
thanks for the replies folks .
itx , according to Wikipedia there could be a problem .
379 , according to the AGA i should be OK .
................... thats if im understanding things correctly .
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
