Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > Installation & Station Setup
Amateur Callsign Lookup
Enter Callsign:
Routing coax out of the cab of a 2006 F150
Reply
  #1
Old 08-22-2011, 08:21 PM
RickC.'s Avatar
Hopeless antenna junkie
RickC. is on a distinguished road
Default Routing coax out of the cab of a 2006 F150
OK, I seldom operate mobile other than my 2m HT, but I joined a new hunting club that uses CBs quite a bit and thought it would be fun to have one in the truck. On my Rangers and other vehicles, finding a convenient grommet under the door sill was no problem. This F150 presents some challenges though.
So I'm asking for suggestions. I really don't want to go through the firewall grommets close to the master cylinder because routing the coax back toward the bed would have it closer to the manifold than I'd like. Also, I have just about killed my hands and lost every bit of Sunday School I ever had trying to get the rear seat popped out (this is an extended cab) to access the rear vents/grommets to route the coax out the rear of the cab. Even with an extra pair of hands and using the tricks I've found on YouTube and the various Ford truck boards, it just will not budge.
I don't want to be stuck with a magnetic mount, so what say ye? (And pics would be nice if you have a extended cab F150 around that year model and you have solved this problem).
Thanks,
Rick
__________________
73 de W4FCC
  #2
Old 08-22-2011, 08:48 PM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
Have you looked under the carpet/floor covering? I haven't seen a truck yet that didn't have at least one opening in the floor (on each side). None there? So make one.
  #3
Old 08-22-2011, 09:26 PM
m42duster's Avatar
Senior Member
m42duster is on a distinguished road
Default
I always make the hole where I want it.
Pick up some grommets...
On my new/newer cars and trucks I would take the time to do it right and guard against leaks and corrosion.
Older vehicles get the quick and dirty install. I has no problems with punching or drilling a hole in a new vehicle.
Sent from my phone.
__________________
"No bastard ever won a war by dying for his country.
He won it by making the other poor dumb bastard die for his country."
~General George Patton, Jr.
  #4
Old 08-23-2011, 05:40 AM
RickC.'s Avatar
Default
Thanks-- two votes so far for one of the options I'm considering anyway.
__________________
73 de W4FCC
  #5
Old 08-26-2011, 05:02 PM
Senior Member
DXman is on a distinguished road
Default
Thanks,
Rick
I have a 09 F150 Super Cab and even tho I don't have the radio in it yet, I don't see any problem of routing the coax.
I will be installing a Wilson 5000 here shortly, it will go through the roof and the coax will come straight down through the headliner. Then I will us Velcro to fasten it to the headliner and route it over to side by the window.
No firewall and no back of cab holes.
__________________
5 element Yagi since '76/I 10K since '09
208 DXCC - 11 mt. (183 DXCC with a 30 watt radio)
  #6
Old 01-01-2012, 10:40 PM
TIN_CAN is on a distinguished road
Default
Well for my self on all my trucks I run wilson 1000 mags mounst and go through the third brake light, as I dont really like drilling in my new trucks.
  #7
Old 01-30-2012, 01:05 PM
Junior Member
Uncle Fester is on a distinguished road
Default
Hello all, I would say if you intend to keep the truck for a number of years, then do what you need to, ie, drill a hole, fit a grommet and seal with silicone if required.
You could always leave the antenna (or complete set up) in the truck when you sell it (it may just seal the deal?)
Buy and install a new set up in your new truck when you get one.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
proper coax choke mobile.. Splash1 CB Antennas 7 09-01-2008 09:05 PM
Common Mode Currents Sonwatcher General CB Services Discussion 3 07-30-2008 08:45 PM
Adjusting SWR with amp T-bone CB Antennas 59 03-27-2008 06:48 PM
BUYING BELDEN COAX CABLE-BEWARE lords Announcements & Open Forum 0 11-06-2007 07:14 PM
Powered by vBulletin®
