Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > Installation & Station Setup
Amateur Callsign Lookup
Enter Callsign:
Coax And Lightning?
Like Tree4Likes
Reply
  #1
Old 03-15-2012, 11:00 AM
Senior Member
Eastside is on a distinguished road
Default Coax And Lightning?
I am trying to figure out what to do with my coax when a lightning storm is on the way...other than pulling it back out the window?
I was thinking of something like a block with so-239 connectors on one side and a ground wire connector on the other side....then running the ground wire out the window to a copper ground rod...so when a storm is coming you just take your coax off your radio and screw it onto the ground block until the storm is over.....do they even sell what I am describing ?
  #2
Old 03-15-2012, 11:32 AM
RatsoW8's Avatar
RatsoW8 is on a distinguished road
Default
It needs to be outside the house. I added a junction box outside the house where I disconnect. If lightning hits and comes in through the coax it will laugh at your ground wire and burn down your house.
__________________
Closet Biker, CB'er and snooty Ham!!
20 wpm Extra
  #3
Old 03-15-2012, 11:42 AM
Senior Member
Default
Quote:
How do you keep the junction box and coax ends from getting all corroded and dirty from being outside?
I need a junction box for 3 coaxes...do you know where I can buy one?
Ok...I understand what you are talking about now...the box is for protecting the connections from the weather.
  #4
Old 03-15-2012, 11:48 AM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt is on a distinguished road
Default
The whole idea is to prevent lightning from passing through your equipment in the first place. If properly grounded, which granted is an extensive endeavor, you should be able to take a direct strike and suffer no damage whatsoever.Few CBer's or hams get that involved however.
http://members.rennlist.org/warren/grounding.pdf
__________________
  #5
Old 03-15-2012, 11:51 AM
AudioShockwav's Avatar
Extraterrestrial Admin
AudioShockwav has disabled reputation
Default
As far as enclosures Look for something like this:
Slimline Junction (3 - 17 in. X 3 in. to 9 in. X 6 in.) Overview
Or
http://www.homedepot.com/webapp/wcs/...ryId=202043419
There are ones that have doors and Gaskets if you want to open them easily.
http://www.automationdirect.com/adc/...s/Metal/NEMA_4
Just search for Nema 4 enclosures
We used them at work to mount stuff in all the time, lots of sizes available.
I have even put small motor starters in them with SO cord in/out and strain reliefs for temporarily installs if we were doing a test run on something.
__________________
Radio-active
NASA/SOHO
there is no dark side in the moon, really. As a matter of fact it's all dark
  #6
Old 03-15-2012, 12:27 PM
BOOTY MONSTER
Guest
Posts: n/a
Default
is there any reason why a nice thick tupper-ware container couldn't be used ? not the thin crappy ones . drill holes on one side for the coax to go in and out of and stand it up to mount it so those holes are on the bottom .
BammBamm likes this.
  #7
Old 03-15-2012, 01:07 PM
Senior Member
Default
Quote:
I guess anything would work that kept the connectors out of the weather...stick the ends in a plastic pop bottle.
  #8
Old 03-15-2012, 01:17 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
Tupperware?!?
You can probably buy a weatherproof junction box from HomeDepot or Lowe's for about ~$10.
Save your Tupperware - Booty!
__________________
BASE: Kenwood TS-2000 w/Alpha Delta DX-CC, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
"...2 WR-011..."
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ham Radio vs Lightning Robb General Ham Radio Discussion 2 12-21-2011 10:22 AM
Antenna and lightning ? BammBamm General CB Services Discussion 40 05-14-2011 11:29 AM
Lightning strike dissapation mackmobile43 Amateur Radio Antennas 7 01-13-2009 02:39 PM
transformerless 3 tuber not working now lightning hit fnkycoldmedina Amplifiers 4 09-08-2006 07:30 PM
President Lincoln hit by lightning sixwheeler General CB Services Discussion 3 05-20-2004 08:48 PM
Powered by vBulletin®
